I would like to have continuous access to OAT via one of the info boxes in
XCSoar. wrote in message ... On Monday, April 15, 2013 4:53:32 PM UTC-5, Dan Marotta wrote: Been looking on the web without much luck. Can anyone tell me if there's a temperature probe which can be plugged into the earphone jack on a Dell Streak 5 and will it be recognized and processed as such by XCSoar? I was thinking of simply moving my probe connector from the back of my CAI302 since it's ridiculously tedious to check OAT on the 302 (10 button presses and 5 rotation clicks!). But then I started to wonder how badly this would affect true airspeed computations. Far as I know, all German gliders that can carry ballast water have an outside air thermometer in the cockpit. Isn't that good enough for you? And yes, I would leave the 302 sensor alone, it is needed for computations. |
On 4/15/2013 4:25 PM, Dan Marotta wrote:
I would like to have continuous access to OAT via one of the info boxes in XCSoar. What will you do with the temperature information? I also got tired of pressing buttons on my 302. I installed a digital food thermometer in the vent duct for $16. It does a good job of reading the air temperature, which I believe is within a degree of OAT because it matches the 302 well. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Well, it's mainly for the geek in me. There's an info box that's unfed and,
frankly I like to know what's going on outside. Ever had a relief tube freeze up? I've fixed that problem... There is no more room on my panel for another device. The 302 will (I think) use a standard atmospheric model to estimate temperature in the absence of a probe but I don't want to risk ice by relying on a standard atmosphere. When's the last time you saw 29.92? All day? A hundred miles away? No, I want to keep the probe with the 302. How about relying on the local forecast as someone else already suggested? Well, if your good day is 3 kts to 6,000' MSL that should work for you but I fly up to 18,000' MSL all year long here in NM. It's that good! BTW, I don't carry water in the cold months. It's too hard to thermal up into the wave in January at 11.9 psf loading. I saw a new device - a temperature sensor attached to a 3.5mm audio plug. It's interesting but I'd have to cut it apart to put the probe in the nose vent and run the wire to my streak. Finally, if my 302 craps out I'd like to have a reasonably accurate temperature fed to the Streak for TAS calculations. It could be the difference in getting home or not. "Eric Greenwell" wrote in message ... On 4/15/2013 4:25 PM, Dan Marotta wrote: I would like to have continuous access to OAT via one of the info boxes in XCSoar. What will you do with the temperature information? I also got tired of pressing buttons on my 302. I installed a digital food thermometer in the vent duct for $16. It does a good job of reading the air temperature, which I believe is within a degree of OAT because it matches the 302 well. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Hi Eric,
Please tell me exactly what thermometer you got and where. I can't find anything suitable on the internet or at the local hardware store. Maybe I'm just not asking the right questions. Dan "Eric Greenwell" wrote in message ... On 4/15/2013 4:25 PM, Dan Marotta wrote: I would like to have continuous access to OAT via one of the info boxes in XCSoar. What will you do with the temperature information? I also got tired of pressing buttons on my 302. I installed a digital food thermometer in the vent duct for $16. It does a good job of reading the air temperature, which I believe is within a degree of OAT because it matches the 302 well. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On 4/17/2013 4:00 PM, Dan Marotta wrote:
Hi Eric, Please tell me exactly what thermometer you got and where. I can't find anything suitable on the internet or at the local hardware store. Maybe I'm just not asking the right questions. I replied privately with a picture, but here are the links: I bought it on amazon.com. Search for "digital food thermometer". This one seems to do the same things, but looks a little different: http://www.amazon.com/Taylor-9842-Co...ref=pd_sim_k_3 The on/off button turns it on and off; also, it will shut off automatically in a minute or so. That's fine with me. I believe, but I'm not positive, that this one has a real on/off button, if you don't want it to turn off automatically. http://tinyurl.com/cqvnnp3 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
Those look great except for the fixed probe. Did you take yours apart and
remote the probe to the vent system? The price is cheap enough that I could afford to risk destroying one (or two)... "Eric Greenwell" wrote in message ... On 4/17/2013 4:00 PM, Dan Marotta wrote: Hi Eric, Please tell me exactly what thermometer you got and where. I can't find anything suitable on the internet or at the local hardware store. Maybe I'm just not asking the right questions. I replied privately with a picture, but here are the links: I bought it on amazon.com. Search for "digital food thermometer". This one seems to do the same things, but looks a little different: http://www.amazon.com/Taylor-9842-Co...ref=pd_sim_k_3 The on/off button turns it on and off; also, it will shut off automatically in a minute or so. That's fine with me. I believe, but I'm not positive, that this one has a real on/off button, if you don't want it to turn off automatically. http://tinyurl.com/cqvnnp3 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
If you use IOIO card to connect your CAI to Streak, you cab build
temperature measurement that connects the inputs of the IOIO. Cost is low, soldering needed. We (soartronic) will try to find time to make explanation how to do it. |
Nah... I use a K6BT so I'm outta luck there. I'm gonna buy one of those
digital meat thermometers, take it apart, and try to mount the sensor remotely. If I fail it's only about 10 bucks. "Kimmo Hytoenen" wrote in message ... If you use IOIO card to connect your CAI to Streak, you cab build temperature measurement that connects the inputs of the IOIO. Cost is low, soldering needed. We (soartronic) will try to find time to make explanation how to do it. |
On 4/18/2013 7:06 AM, Dan Marotta wrote:
Those look great except for the fixed probe. Did you take yours apart and remote the probe to the vent system? The price is cheap enough that I could afford to risk destroying one (or two)... "Eric Greenwell" wrote in message ... On 4/17/2013 4:00 PM, Dan Marotta wrote: Hi Eric, Please tell me exactly what thermometer you got and where. I can't find anything suitable on the internet or at the local hardware store. Maybe I'm just not asking the right questions. I replied privately with a picture, but here are the links: I bought it on amazon.com. Search for "digital food thermometer". This one seems to do the same things, but looks a little different: http://www.amazon.com/Taylor-9842-Co...ref=pd_sim_k_3 The on/off button turns it on and off; also, it will shut off automatically in a minute or so. That's fine with me. I believe, but I'm not positive, that this one has a real on/off button, if you don't want it to turn off automatically. http://tinyurl.com/cqvnnp3 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl No, I just stuck in through a hole in vent duct near the eyeball vent, and it reads the OAT within a degree F. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more | Evan Ludeman[_4_] | Soaring | 2 | December 31st 12 12:14 AM |
Dell Streak 5 available | soartech[_2_] | Soaring | 0 | November 14th 12 05:44 PM |
Short review of the Dell Streak with XCSoar | Max Kellermann | Soaring | 6 | February 9th 11 04:22 PM |
Location for temperature probe in ASG 29? | Tuno | Soaring | 2 | March 28th 08 06:32 AM |
Outside air temperature probe | dlevy | Owning | 9 | November 7th 06 05:14 PM |
