If you use IOIO card to connect your CAI to Streak, you cab build
temperature measurement that connects the inputs of the IOIO. Cost is low, soldering needed. We (soartronic) will try to find time to make explanation how to do it. |
Nah... I use a K6BT so I'm outta luck there. I'm gonna buy one of those
digital meat thermometers, take it apart, and try to mount the sensor remotely. If I fail it's only about 10 bucks. "Kimmo Hytoenen" wrote in message ... If you use IOIO card to connect your CAI to Streak, you cab build temperature measurement that connects the inputs of the IOIO. Cost is low, soldering needed. We (soartronic) will try to find time to make explanation how to do it. |
On Apr 18, 7:01*pm, "Dan Marotta" wrote:
Nah... *I use a K6BT so I'm outta luck there. *I'm gonna buy one of those digital meat thermometers, take it apart, and try to mount the sensor remotely. *If I fail it's only about 10 bucks. "Kimmo Hytoenen" wrote in message ... If you use IOIO card to connect your CAI to Streak, you cab build temperature measurement that connects the inputs of the IOIO. Cost is low, soldering needed. We (soartronic) will try to find time to make explanation how to do it. Here's another option: http://www.digitalthermometers.net/m...dp300pp.asp x Bob Faris |
No need to take apart thermometers. Every Walmart and hardware store
carries small digital thermometers that have an "outside" wired sensor for less than $10. Put the sensor in your vent and stick the little display anywhere. It never turns off either. To get temperature into your Dell Streak use the IOIO box and a serial output temp sensor. Something like this: http://www.microchip.com/paramcharts...branchID=90003 |
That.s perfect, Bob!
I'd already ordered another unit that I'll have to modify for my needs and, if I fail, I'll get the one you suggested. My only concern is that the wires might be too short, but I can fix that easily. "Bob Faris" wrote in message ... On Apr 18, 7:01 pm, "Dan Marotta" wrote: Nah... I use a K6BT so I'm outta luck there. I'm gonna buy one of those digital meat thermometers, take it apart, and try to mount the sensor remotely. If I fail it's only about 10 bucks. "Kimmo Hytoenen" wrote in message ... If you use IOIO card to connect your CAI to Streak, you cab build temperature measurement that connects the inputs of the IOIO. Cost is low, soldering needed. We (soartronic) will try to find time to make explanation how to do it. Here's another option: http://www.digitalthermometers.net/m...dp300pp.asp x Bob Faris |
Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more | Evan Ludeman[_4_] | Soaring | 2 | December 31st 12 12:14 AM |
Dell Streak 5 available | soartech[_2_] | Soaring | 0 | November 14th 12 05:44 PM |
Short review of the Dell Streak with XCSoar | Max Kellermann | Soaring | 6 | February 9th 11 04:22 PM |
Location for temperature probe in ASG 29? | Tuno | Soaring | 2 | March 28th 08 06:32 AM |
Outside air temperature probe | dlevy | Owning | 9 | November 7th 06 05:14 PM |
