You should not be able to remove the spar pins from the fuselage..
You should only be able to move them out of the spar, and they stay fixed in front of the spar. On my LS-1f, the spar pins slide out of the spar, and remain forward of the spar by about two inches. Email your address and I will send you pictures. I can also measure the pins when I am out at the gliderport tomorrow. Scott Alexander liv2soar (at) yahoo (dot) com |
| Thread Tools | |
| Display Modes | |
| Alignment tool for spar pins | soartech[_2_] | Soaring | 5 | September 6th 12 06:39 PM |
| Glass spar-carbon skins question | Brad[_2_] | Soaring | 4 | September 7th 07 07:06 AM |
| Newbie question about the spar and building | Randy | Home Built | 6 | January 21st 07 09:19 PM |
| misdrilled hole on on tubular aluminum spar question | patrick mitchel | Home Built | 12 | October 2nd 06 09:17 PM |
| ASW-15B spar pins | [email protected] | Soaring | 1 | May 9th 06 01:46 AM |
