Why not put an audible variometer in every glider?
Old June 5th 13, 02:44 AM posted to rec.aviation.soaring
son_of_flubber
Default Why not put an audible variometer in every glider?
On Tuesday, June 4, 2013 5:48:07 PM UTC-4, Martin Gregorie wrote:
As I mentioned previously, all gliders in our club fleet carry audio
varios and FLARM. Part of a student's training involves learning to put
the batteries in gliders at the start of the day and taking them out and
putting them on charge in the evening. How is that different from doing
the same with the 'chutes and being involved in hangar packing and
helping with the DI in the morning?
Audio varios, FLARM, parachutes? In a club glider??
Old June 5th 13, 11:56 AM posted to rec.aviation.soaring
And radios. Why wouldn't you? We're training people to be cross country pilots.
Paul
Old June 5th 13, 12:21 PM posted to rec.aviation.soaring
son_of_flubber
We've circled back to the original topic question that I posted. Is there really such a stark contrast between UK and USA pilots on this matter? I wonder if it springs from the government regulation of USA gliding by the FAA, whereas UK gliding is "self-regulated" by the BGA.
Old June 5th 13, 02:53 PM posted to rec.aviation.soaring
What does the FAA have to do with this all? I don't get it... Just like in the UK, most gliders in Germany and France are club-owned and very well equipped and yes, that included audio varios even back in the 80's when I flew there. Parachutes were mandatory for all seats even back then.
Herb
Old June 5th 13, 05:22 PM posted to rec.aviation.soaring
son_of_flubber
Herb
How do you explain the starkly contrasting attitudes (between UK/Germany/France and the USA) wrt equipping trainers? I'm grasping at straws when I raise the BGA vs. FAA/SSA/NTSB/AOPA regulatory approaches, but those approaches, and the regulations, and the equipment of trainers is quite different. Perhaps the regulatory environment affects our attitudes and behavior, especially when so many regulations are known or taken to be bogus. (For example the FARs wrt oxygen use are known to be based on wrong and out-of-date scientific knowledge.)
Old June 5th 13, 06:03 PM posted to rec.aviation.soaring
How do you explain the starkly contrasting attitudes (between UK/Germany/France and the USA) wrt equipping trainers? I'm grasping at straws when I raise the BGA vs. FAA/SSA/NTSB/AOPA regulatory approaches, but those approaches, and the regulations, and the equipment of trainers is quite different.. Perhaps the regulatory environment affects our attitudes and behavior, especially when so many regulations are known or taken to be bogus. (For example the FARs wrt oxygen use are known to be based on wrong and out-of-date scientific knowledge.)
A quick look at the (UK BGA) regulations shows using a parachute is a recommended practice, as is the use of an audio vario. However, radio is not mandated, nor FLARM. But radio is very (90%) common in the 100 or so gliders at my club. FLARM is present in 50% and increasing of cross country gliders, and 100% of the 11 club gliders. I think these things become expected - and as Martin pointed out, are safety issues in high traffic density airspace.
Paul
RICO audible vario manual? tstock Soaring 0 July 4th 11 07:45 AM
Moore Variometer EdByars Soaring 0 April 13th 10 04:29 PM
WTB: Sage CVA variometer Fox Two Soaring 0 July 12th 06 09:59 PM
Variometers as audible AOA indicators Jeff Dorwart Soaring 0 March 17th 04 02:52 AM
Variometers as audible AOA indicators John Soaring 1 March 17th 04 02:02 AM
