On Sunday, June 9, 2013 10:15:07 AM UTC-7, Bill D wrote:
If you plan to use the gliders 12V bus, the LED's need the resistor. (FWIW, non-rechargeable lithium cells output 3.7V which is just right for an LED without resistor as millions of key-ring flashlights show.) An LED is a diode junction, forward voltage is around 0.7 to 1.1V typically. 3.7V will make a single diode glow very brightly for a very short time. Cheap flashlights usually have 3 or 4 LEDs in series to accommodate the higher voltage. |
On Sun, 09 Jun 2013 12:38:47 -0700, jfitch wrote:
On Sunday, June 9, 2013 10:15:07 AM UTC-7, Bill D wrote: If you plan to use the gliders 12V bus, the LED's need the resistor. (FWIW, non-rechargeable lithium cells output 3.7V which is just right for an LED without resistor as millions of key-ring flashlights show.) An LED is a diode junction, forward voltage is around 0.7 to 1.1V typically. 3.7V will make a single diode glow very brightly for a very short time. Cheap flashlights usually have 3 or 4 LEDs in series to accommodate the higher voltage. Look at the maximum current rating of the LEDs, assume the LED has no resistance and calculate the series resistor value from R = V/I where I is the maximum rated current for the LED in amps, V is the supply voltage in volts and R is the inline resistor in ohms. Round the resistor UP to the next highest standard resistor size and fit that resistor size in series with each LED. This will give near maximum brightness. Try doubling the resistor's value if its too bright. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Ventus C (1986) - Flap and Gear Indicator | Ken Kochanski (KK) | Soaring | 3 | January 19th 10 01:33 PM |
Replacing PA28 panel dimmer rheostat/position light switch | Mike Noel | Owning | 4 | December 1st 08 12:16 AM |
C172N Flap indicator problem | onesto | Owning | 0 | July 2nd 06 10:47 AM |
EAA position on ADIZ... | .Blueskies. | Piloting | 0 | November 2nd 05 12:16 AM |
Replacing position light bulbs | Mutts | Piloting | 15 | December 30th 03 09:55 PM |
