Canopy open incident.
Old June 17th 13, 03:22 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
Default Canopy open incident.
On Sun, 16 Jun 2013 14:15:43 +0100, Walt Connelly
[snip]
One might think that an engineer could design a system which would
overcome the force on the tow hook which exceed the pilot's ability to
pull the release. I've heard of a condition like this happening when
the glider pilot "thought" he had released and in fact had not. Never
sure how things like that happen.
There was a tow-pilot fatality at my former gliderport years ago, in
which the towpilot apparently couldn't reach the release handle while
he was holding full back stick to avoid being nosed into the ground.
Old June 17th 13, 09:08 PM posted to rec.aviation.soaring
ProfChrisReed
I think the original poster made the best decision. Those saying he should have pulled off immediately and landed ahead can only speak with any authority if they've achieved that in a similar situation.
My canopy opening incident was while winch launching a Grob Astir. It appears from the witness marks that my sweatshirt was caught in the canopy lock, behind my shoulder and thus not visible, so the part of the mechanism I could see was engaged and a push up on the canopy didn't move it. A bump on the ground run pulled my sweatshirt loose and the canopy began to open as I rotated into the climb. RH hinged, so I automatically pushed it closed with my left. By then I'm 50ft into the climb and the thinking begins, starting with "fly the aircraft". By the time I've worked out the next course of action (hang on to canopy, because if it opens and breaks away my elevator might go with it, in which case it's goodnight) I'm at 200 ft and climbing. This is not too much height to land ahead on a 3,000 ft runway *if* (and only if) I can use the airbrakes - with my left hand, which is holding the canopy closed. So I rode the launch to the top.
Then some interesting attitudes while I failed to lock the canopy, followed by some experimenting with the airbrake. As I could use my elbow to modulate it between full and half open I set up for a full airbrake approach to the start of the runway, and used the modulation to land me a safe margin beyond that point. A non-event in the end, like the original poster.
As the commentary in the video says, by the time the pilot had everything under control there was still a land-ahead (actually 30 degree turn to a taxiway) option. But that option had to be flown with the aircraft in an unknown configuration - could he operate all the necessary controls? would 200ft of height be enough time to learn? The problem was a known one, and there was no further danger of the canopy disappearing, so I'm certain the right thing to do was to gain height. I'd have ridden the tow to 2,000 ft, to give me the option of using the parachute if I couldn't make the glider controllable for landing.
And let me stress the elevator again. If the canopy detaches at 50ft and knocks off the tailplane, that's probably not survivable. Hold the damned thing on, and work out a better plan!
Old June 17th 13, 10:19 PM posted to rec.aviation.soaring
Bill D
I can't see anything in the argument below that suggests either course of action would be preferable. Land ahead or fly away, the glider is in an unknown condition. Land or fly, you have to operate the controls. A canopy that has slammed open is bent or broken and won't close no matter how long the flight is extended.
If the flight does continue, the situation may snowball into something deadly. Accidents are a chain of events and several are in play as soon as the canopy opens. Extending this situation increases the chances something unexpected will add to the pilot's problem taking it beyond what the pilot can deal with. The canopy wasn't latched, perhaps the spoilers aren't locked either. Maybe the seat slips back from the pilots contortions. In this situation it would only take a minor event.
Releasing and landing ahead, as long as you have the room, is an excellent option not to be discarded lightly. It's fundamental to flight crew training that if somethings goes wrong with the aircraft while there's still room to stop, then damn it STOP! The question is, can you do it? If not, why not? People practice 200 foot rope breaks why not practice landing ahead when there's room?
I can't find a single incidence of an accident landing ahead after a malfunction but there's no problem at all finding fatal accidents where the pilot tried to fly a disabled aircraft. Anybody remember Clem Bowman?
A340 Incident K&FKeam Aviation Photos 38 May 13th 08 02:05 AM
Accident or Incident? [email protected] Piloting 4 February 11th 06 03:20 AM
Curious incident :) Ramapriya Piloting 23 December 22nd 05 07:03 AM
LAS incident H.P. Piloting 11 October 3rd 05 02:37 AM
NY incident :-( Rosspilot Piloting 33 December 31st 03 11:41 PM
