Cobra Top Hinge Bolt Failure - Revisit
Old June 18th 13, 10:18 PM posted to rec.aviation.soaring
Dave Nadler
Default Cobra Top Hinge Bolt Failure - Revisit
On Tuesday, June 18, 2013 4:14:30 PM UTC-4, wrote:
Just thought I would report - I was able to fabricate some parts out of aluminum channel and steel channel based on Dave's design and document. Mine was done without welding since I am not a welder, but riveted to the side rail. An additional piece of aluminum sq tubing was added to the shell behind the side rail as piece of mind should the side rail want to twist. I am happy to report that after gradually torquing the jacking bolt, and shifting the top maybe 1/4 inch, the shell closes a lot better. I needed it more on one side than the other and this design helps addresses it well. I highly recommend this approach if you find the closing the trailer top is difficult on your fiberglass Cobra and see clear evidence of the top shifting fwd. It took me one week, couple hours each evening to fabricate the pieces and I'm not a machinist.
Darren
Very Nice ! Send me some pictures, lets get it on a web site somewhere...
Onwards to Hobbs !
See ya, Dave "YO electric"
  #32
Old June 19th 13, 06:12 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote, On 6/18/2013 2:18 PM:
machinist.
Darren
somewhere... Onwards to Hobbs ! See ya, Dave "YO electric"
Yes, indeed. I want to see those pictures, too.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
  #33
Old June 19th 13, 06:36 PM posted to rec.aviation.soaring
I'll try to get some pics. One thing to add to the procedure, if it is not already mentioned, after shifting the trailer top, one must re-adjust the wing dolly "keepers" or restraints. You'll want to snug those up again so the wings remain constrained during transport.
Cobra top hinge plate bolt failure Andy[_1_] Soaring 43 May 24th 11 03:41 AM
Cobra top hinge plate bolt failure Steve Koerner Soaring 19 May 22nd 11 03:30 PM
Cobra top hinge plate bolt failure JJ Sinclair[_2_] Soaring 0 May 18th 11 07:45 PM
Cobra top hinge plate bolt failure Andy[_1_] Soaring 0 May 17th 11 12:01 AM
Cobra bottle jack failure db_sonic Soaring 15 October 30th 09 03:34 PM
