On Monday, September 16, 2013 3:30:27 PM UTC-4, bumper wrote:
On Wednesday, September 4, 2013 8:01:59 PM UTC-7, Juanman wrote: Anyone have experience installing a PowerFLARM in a Duo? Juan LI Sorry Juan, I don't, though thought I'd mention that it is far better to have the antennas closer to the "Core" box than further away in order to minimize line loss in the coax. The center fed dipole antenna leads are easy to shorten at the antenna end . . . moderate soldering skill required. I've done previous posts on the procedure. all the best, bumper Thanks Bumper. We were able to install the core under the front panel. The Flarm antenna is a problem because it hits the canopy if put in the front of the panel. We may have to build a small bridge to bring it further back. |
Have you done a Discus 2CT Transponder Antenna Installation per863-17 (behind turbo on top of fuse)?? | [email protected] | Soaring | 0 | December 20th 12 01:45 PM |
FLARM Installation | Boise Pilot | Soaring | 11 | April 5th 12 03:25 PM |
FLARM antenna installation | Kevin Neave | Soaring | 5 | January 16th 07 06:53 PM |
Transponder Installation in Discus A, B, CS | Rick Fuller | Soaring | 0 | March 27th 04 11:13 AM |
Discus CS and Duo Discus Wing Inspections | Nolaminar | Soaring | 0 | October 24th 03 01:15 AM |
