#11
If you haven't already read it, you should also look at "Streckensegelflug"
by Helmut Reichmann: http://www.amazon.com/Streckensegelf.../dp/3613024799 "son_of_flubber" wrote in message ... Thank you for the recommendations made here. I've just ordered copies of: "Fundamentals of Sailplane Design" by Fred Thomas. "Radio Control Thermal Gliding" by Markus Lisken and Ulf Gerber Good reading for the winter ahead. |
On Sunday, October 6, 2013 1:47:40 PM UTC-4, Dan Marotta wrote:
If you haven't already read it, you should also look at "Streckensegelflug" Ich habe nur eine bischen deutsch. |
I get the 45 degree bank by looking at the screws of my instruments. Since the screws are placed in the "corners" of the non-existent square hole, the diagonals are 45 degrees to vertical/horizontal.
When I bank over, I check that a diagonal parallels the horizon (I'm a flat-lander) and the other is perpendicular. Easy-peasy! Now, if I can just stabilise my speed and the angle, I might improve my thermalling. I keep working on that ![]() |
At 20:38 06 October 2013, C-FFKQ 42 wrote:
snipNow, if I can just stabilise my speed and the angle, I might improve my thermalling. I keep working on that ![]() Actually, stabilising the attitude (not the speed) is what helps ... although the two are very similar in typical flatland thermals. J. |
At 17:48 05 October 2013, son_of_flubber wrote:
I know that a 45 degree bank is useful for flying small circles and staying in small thermals, but is there something special about a 45 degree bank compared to say a 50 degree bank? For example, does the designer intend for the glider to do something special at 45 degrees? Is the glider designed to balance aerodynamic forces in a particular harmony at a precise 45 degree bank? The only thing I am aware of in relation to 45 deg of bank, is that it gives the minimum height loss in a 360 deg turn. This is not of much help in turns in thermals. Dave |
If that means you don't speak German, fear not. It's published in English.
"son_of_flubber" wrote in message ... On Sunday, October 6, 2013 1:47:40 PM UTC-4, Dan Marotta wrote: If you haven't already read it, you should also look at "Streckensegelflug" Ich habe nur eine bischen deutsch. |
Silly Flubber. Everyone knows the special number is 42.
One thing special about 45 degrees is that it is the only angle you can really measure in flight without artificial horizon. If the horizon is aligned with your instrument screws you are banked 45 degrees. You will often be surprised how steeper it is then you thought.
Ramy |
Pesky mountains ruin the horizon so I can't use the screws. Maybe I should
move to Kansas. Steve...? "Ramy" wrote in message ... One thing special about 45 degrees is that it is the only angle you can really measure in flight without artificial horizon. If the horizon is aligned with your instrument screws you are banked 45 degrees. You will often be surprised how steeper it is then you thought. Ramy |
On Monday, October 7, 2013 11:19:01 AM UTC-5, Dan Marotta wrote:
Pesky mountains ruin the horizon so I can't use the screws. Maybe I should move to Kansas. Steve...? Stick with New Mexico and the uncertainty of your bank angle. |
60 degree Mopar V6 for homebuilt? | RapidRonnie | Home Built | 17 | February 9th 07 04:12 AM |
90 degree locking pliers? | B. Jensen | Home Built | 8 | October 3rd 05 06:50 PM |
37 degree fitting | Ernest Christley | Home Built | 8 | June 17th 04 03:29 AM |
90 Degree turn while slipping | ISoar | Soaring | 40 | February 14th 04 10:49 AM |
37 degree flare, 1/8" stainless | Richard Riley | Home Built | 8 | August 29th 03 04:21 AM |
