Butterfly display (displaying a big red logo under normal flight conditions)
Old October 15th 13, 04:06 PM posted to rec.aviation.soaring
Juanman
Default Butterfly display (displaying a big red logo under normal flight conditions)
On Monday, October 14, 2013 10:03:07 PM UTC-4, SF wrote:
I can't see my Butterfly Display most of the time, as a result I only look at it when the circle of death pops up. Other than that one function I find it almost worthless. From what I can discern I'm not the only dissatisfied customer, the trade in value is zero. The LXNAV FlarmView appears to be a better product. Maybe the Butterfly guys should branch out into Graphic design services since that is what they seem to be the most proud of. Does it work better if you keep your hand on it during launch? Maybe the dim display is the result of global warming. Or it could be the result of some right wing extremist plot. All they need is better marketing, that will fix it right up.
I agree, it is a very poorly designed display. It's so dark that with sunglasses on I can't see anything. And the letters/numbers are still very small. Fortunately I connected the PowerFlarm to my Oudie where I can clearly see the other Flarm equipped gliders and receive a legible warning when necessary. I also have it connected to the SN10 which tells me in what direction to look for the oncoming traffic.
Old October 15th 13, 04:59 PM posted to rec.aviation.soaring
Ramy
Folks the issue is polarization. The butterfly display is plenty bright but if you use polarized sunglasses you can only use the display in vertical orientation. I hope butterfly will eventually address this issue and provide additional polarization option. No issue with the panel display only the rectangular.
Ramy
Old October 16th 13, 02:48 PM posted to rec.aviation.soaring
Juanman
Ramy
Beg to disagree. I have the panel display and even without glasses it is half as bright as my other instruments. And the letters/numbers are still small even after the latest software upgrade.
Old October 16th 13, 03:39 PM posted to rec.aviation.soaring
Marc - Butterfly Avionics
Juan, SF,
please get in touch with us and provide pictures of your installation and close-ups of your display:
Its a transflective display - it gets brighter in sunlight and looks dim when not in sunlight. If you install it in an unfavorable angle or in the shadow of your glareshield, or if using polarized glasses it won't bring much fun using it.
Looking forward to helping you.
Marc
Old October 17th 13, 03:39 AM posted to rec.aviation.soaring
Juanman
On Wednesday, October 16, 2013 10:39:22 AM UTC-4, Marc - Butterfly Avionics wrote:
Juan, SF,
Marc
Will try to take pictures before our season winds down.
New Butterfly Display Software 3.2 Marc - Butterfly Avionics Soaring 36 March 8th 15 08:16 PM
New Butterfly Display Software 3.2.1 released Marc - Butterfly Avionics Soaring 27 August 28th 13 02:11 PM
Flarm Butterfly display [email protected] Soaring 10 May 6th 13 05:40 PM
Updating Software on Butterfly 57 mm version 2.1 display w/o Cable? 3Y Soaring 7 December 31st 12 12:50 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 07:20 AM
