Butterfly display (displaying a big red logo under normal flight conditions)
Old October 18th 13, 05:35 PM posted to rec.aviation.soaring
Ramy
Default Butterfly display (displaying a big red logo under normal flight conditions)
I know of at least 5 pilots flying with portable and transponder and have no false alerts. I only know one locally who has the same issue. I would also like to hear the response from the factory. It seem that portables have more issues than brick. I recommend people to get the brick.
Ramy
Old October 18th 13, 06:45 PM posted to rec.aviation.soaring
Thinking again about the displays...
the Portable unit has the large radar screen, with the bottom sliver cut off (and thats ok!) giving good situational awareness (SA) to the sectors of interest, large icons, etc.
The BF display has the complete radar screen, with data to the right. So this display is more setup for a tactical awareness (TA) purpose.
If/When the BF team get around to bringing their products back in-line to each other, it would be nice for the user to be able to select the option of either the SA or the TA display.
I agree with the statement that any rotation of the knob should be first and foremost for zoom levels, rather than target selection.. heck that could be another user selectable feature.
-Britton
Old October 18th 13, 08:48 PM posted to rec.aviation.soaring
Andy[_1_]
On Friday, October 18, 2013 9:35:13 AM UTC-7, Ramy wrote:
I know of at least 5 pilots flying with portable and transponder and have no false alerts. I only know one locally who has the same issue. I would also like to hear the response from the factory. It seem that portables have more issues than brick. I recommend people to get the brick. Ramy
You're just not getting it. The latest firmware fixes the spurious own transponder alerts at the expense of reliable co-altitude alerting. Saying that you have no spurious alerts contributes nothing. Tell me instead about how many alerts you have had for transponder targets that maintained the same altitude as you while in the alerting volume.
If you fly only a glider you may never see this scenario. If you fly a powered airplane then it is not only possible but likely.
Andy
Old October 19th 13, 12:51 AM posted to rec.aviation.soaring
Ramy
Ok, I missunderstood your comment. I suspect this suppression only happens at the exact same altitude consistsntly. I didn't notice targets disappearing when flying together, and I am flying with latest firmware since it was released. I assume their algorithm is smart enough to make it a non issue. Did you experienced targets disappearing when you fly power at the same altitude as other traffic?
Ramy
New Butterfly Display Software 3.2 Marc - Butterfly Avionics Soaring 36 March 8th 15 08:16 PM
New Butterfly Display Software 3.2.1 released Marc - Butterfly Avionics Soaring 27 August 28th 13 02:11 PM
Flarm Butterfly display [email protected] Soaring 10 May 6th 13 05:40 PM
Updating Software on Butterfly 57 mm version 2.1 display w/o Cable? 3Y Soaring 7 December 31st 12 12:50 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 07:20 AM
