Aerotow ropes: short or long, breakable or unbreakable?
Old November 12th 13, 04:22 PM posted to rec.aviation.soaring
son_of_flubber
Default Aerotow ropes: short or long, breakable or unbreakable?
With the dewpoint at 15d F. today, I'm ready to heat things up.
Regulations on aerotow ropes vary by region. What is the evidence to support the various approaches?
PTT (Premature Termination of Tow)(aka rope break) correlates with a number of fatal accidents. How often has a hard_to_break towrope led to a fatal accident?
Options to land after a PTT vary by airport and can be non-existent at certain altitudes. Why is an extra strong towrope not an option where the straight-ahead landing option is poor or non-existent?
In what year did the FAA set the FAR for towropes and what was the quality of towropes at that time? (obscure, but interesting question).
At the airport where I am towed, the same towrope satisfies the FAR for both the frequently towed heavier two-seater, and my less frequently towed lighter weight single place glider. Does this mean that the two-place is more likely to break the towrope?
Old November 12th 13, 06:21 PM posted to rec.aviation.soaring
On Tuesday, November 12, 2013 11:22:14 AM UTC-5, son_of_flubber wrote:
With the dewpoint at 15d F. today, I'm ready to heat things up. Regulations on aerotow ropes vary by region. What is the evidence to support the various approaches? PTT (Premature Termination of Tow)(aka rope break) correlates with a number of fatal accidents. How often has a hard_to_break towrope led to a fatal accident? Options to land after a PTT vary by airport and can be non-existent at certain altitudes. Why is an extra strong towrope not an option where the straight-ahead landing option is poor or non-existent? In what year did the FAA set the FAR for towropes and what was the quality of towropes at that time? (obscure, but interesting question). At the airport where I am towed, the same towrope satisfies the FAR for both the frequently towed heavier two-seater, and my less frequently towed lighter weight single place glider. Does this mean that the two-place is more likely to break the towrope?
There are no regulations that vary by region, but practices may vary in different operations.
I personally have never heard of an accident caused by a rope that was too strong. Over the years there have been a few accidents caused by rope breaks at low altitude and at least one fatality that I recall out west. Whether this was due to selected rope strength or wear, or both, I don't know.
All failures of ropes at our operation are at the time of initial acceleration when a worn rope that has not been inspected fails at the ring. Stronger ropes tend to reduce the liklihood of this happening in my experience.
Avoiding the use of short ropes is a good way to help ensure long tow pilot life. Errors in glider positioning are magnified by short ropes.
Long, strong, inspect.
FWIW
UH
Old November 12th 13, 07:58 PM posted to rec.aviation.soaring
In the case of aerotow upset, if the rope doesn't break the towplane and glider will both hit the ground. That's a good reason to have a weaklink (or weak rope). I know of four tow upsets where I fly, fortunately all high enough to not hit the ground. Three weak links let go, one towpilot released manually. The towpilot who released had his first upset a week before the second, so he was primed and ready on the release.
Philip Plane
Old November 12th 13, 11:36 PM posted to rec.aviation.soaring
son_of_flubber
I thought that the concept of a breakable towrope was considered misguided in South Africa.
Old November 13th 13, 01:13 AM posted to rec.aviation.soaring
SF
I have has some interesting experiences with students. Normally the rope breaks during the initial acceleration on the ground, which is no big deal. I had one student that was low and to the left on tow at altitude and briskly put the plane into a 45 Degree left bank before I could catch it. The rope broke, and at that point I think that the tow pilot and I really wanted it to break because the glider and the tow plane were not friends at that point. Long ropes are easier on everyone involved. long tows on short ropes are pretty nerve wracking. Why make something potentially dangerous harder to do? After my experience with the student I think that you should use a rope that will break at the appropriate load or use the weak link in the POH for winching. The student that broke the rope at altitude never came back and that was probably a very good thing. He seemed to have no concept of wings level, which was almost surprising since he was a high time power pilot that had recently decided not to renew his medical. can you say "Danger Will Robinson, Danger"
Old November 13th 13, 01:43 AM posted to rec.aviation.soaring
WAVEGURU
Tow ropes don't always break during the initial acceleration. I had one go on me at about 150ft, and it didn't go bang, it was just sort of a soft fffffftt. I almost couldn't believe it as I watched the frayed end run away from me.
Boggs
Old November 13th 13, 02:37 AM posted to rec.aviation.soaring
son_of_flubber
This rational makes perfect sense, so why do the Europeans use shorter tow ropes that the North Americans? Is it just "common sense and tradition" or do the accident statistics prove one approach better than the other?
Old November 13th 13, 02:43 AM posted to rec.aviation.soaring
Cookie
I have a number of questions about tow ropes on my Pre solo written test which I give to my students.
After explaining the FAR's , I then ask them, "thinking as a glider pilot, would you rather have a tow rope which is on the stronger side, or on the weaker side?" They almost always answer "stronger", and I agree. But I caution, stronger within reason. In my way of thinking...I have the option to pull the release if things get too gnarly...but at least that release is on my terms, not the rope's.
My rough calculations show that the "normal" tension on a tow rope in smooth tow is very low...It is basically the drag on the glider, plus a tiny bit extra due to the climb vector...so maybe 60 lbs tension...
Almost all ropes I've seen at glider ports are in the 2000 lb breaking strength area....so rope breaks "should" be unlikely. But obviously they do break...so I attribute this to wear of damage....
I think the 80% ~ 200% is a pretty good "rule"...but again I want close to the 200%.
In 8000 flights, I have had 5 (if I remember correctly) tow rope "incidents".
Only two were classic rope breaks...and these happened on the ground roll..where the rope tension is quite high.
Another was a failure at the attachment of the rope to a weak link, not the rope actually breaking...(long story here)
another was the failure of the tow ring...but this was not an "approved" tow ring...it was somebody's idea of a "new and improved" ring...which of course failed...luckily at 400' and we were certainly expecting it. Funny thing about this one...it was in 2-33....at 400' I heard "tink"....which I figured was the tow ring breaking. We returned to the airport to find that the ring was in perfect condition. We looked at the tow hook on the Schweizer and it was still closed and in perfect condition. The guy in front was flying at the time...he got a bit of slack in the rope, when the slack come out, the rope was disconnected. What I think happened was the slack allowed the ring to twist around and back release the schweizer hook. They have a habit of bouncing back closed so it looked like it never released and the ring separated as if by magic.
Lastly, while doing a scenic ride, I noticed something first near the tow plane, which then seemed to be headed toward me...a black thing....turns out this was part of the tail spring, to which the tow rope was attached. It came straight and level back toward me for quite a while, but then finally arced and fell under the glider. So again, not a real rope break.
As for rope length..some operators will cut out a short section of worn rope at the end, and splice it back on the ring...so over time the rope gets shorter and shorter. I has a tow just last week with a student...and a really short rope. First of all, that Pawnee looked really "big"...but the student had a bit more trouble on tow than usual.
I've done long distance tows, where we attached two 200' ropes together to give 400' tow rope. This is luxury! The interaction between glider and tow plane is cut down dramatically!
Cookie
Old November 13th 13, 04:16 AM posted to rec.aviation.soaring
GM
The 80-200% rule is in the FARs but it DOES NOT APPLY to ANY glider which - at the time of US-certification (standard or experimental) - had a manufacturer's issued and approved POH, which spelled out the breaking strength of a weak-link for the CG and aero-tow hook! In some cases, these may be the same; in most cases, the aero-tow weak-link strength is lower.
In Europe, typically very strong tow ropes (mooring lines, as one US visitor to Europe called them) are used but there is a proper weak-link attached on the glider end.
A short while ago, I did launch a quick survey on the German forum to find out how many tow rope failure anyone had. The response: zero tow rope failures!
Old November 13th 13, 11:50 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
It's rare, but I have twice seen ropes break when they snagged something solid while the tug was on final. Something to consider before going to an "unbreakable" rope with a weak link only at glider end.
T8
long range aircraft flying short-range routes? tupolev204 Piloting 10 April 22nd 11 07:44 PM
FAA Administrator and FAA on the ropes and going broke PapaFoxTrot Piloting 0 September 16th 08 03:33 PM
Charging system failure cuts short a long X-Country Ron Lee[_2_] Piloting 10 November 15th 07 11:04 PM
Tow Ropes [email protected] Soaring 6 July 15th 05 07:39 PM
Plasma Ropes ----- Help Dave Martin Soaring 7 September 30th 03 11:23 PM
