On Tue, 12 Nov 2013 18:43:41 -0800, Cookie wrote:
My rough calculations show that the "normal" tension on a tow rope in smooth tow is very low...It is basically the drag on the glider, plus a tiny bit extra due to the climb vector...so maybe 60 lbs tension... I think its a bit more than that, but not much. Some time ago I did a fairly detailed spreadsheet calculation for my Libelle being towed at 60 kts in a 600 fpm climb and got a total rope tension of 37.62 kg, which was more or less what I'd guestimated from a mental round number calculation. The makeup of the rope tension did surprise me though: like you I thought drag would be the major part of it, but the spread sheet gave the glider's drag as 9.97 kg and the force needed to haul my 280 kg Libelle up a 5.67 degree slope at 60kts as 27.65 kg. Yeah, I know, I should have only kept 1 decimal point: 2 decimals is spurious accuracy. Of course, the other interesting number would be what fraction of the total drag of a climbing tug+glider combination was due to the glider. I suspect the glider is contributing less than Wg/Wt where Wg is the glider weight and Wt is the tow planes's weight. I'd expect the straight ratio to over-estimate the glider's contribution because it is likely to fly rather more efficiently than the tug. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
yes, I underestimated....
Say a 800 lb glider at 40:1 L/D so the drag is about 20 lbs...but the tension component in the rope due to the climb angle (say 10:1) is going to be 80lbs....so you've got 100 lb tension on the rope. But a rope "in spec" would offer a safety factor of 6x up to 16x. Some tow planes can climb better than that...so more tension... Cookie At 23:46 13 November 2013, Martin Gregorie wrote: On Tue, 12 Nov 2013 18:43:41 -0800, Cookie wrote: My rough calculations show that the "normal" tension on a tow rope in smooth tow is very low...It is basically the drag on the glider, plus a tiny bit extra due to the climb vector...so maybe 60 lbs tension... I think its a bit more than that, but not much. Some time ago I did a fairly detailed spreadsheet calculation for my Libelle being towed at 60 kts in a 600 fpm climb and got a total rope tension of 37.62 kg, which was more or less what I'd guestimated from a mental round number calculation. The makeup of the rope tension did surprise me though: like you I thought drag would be the major part of it, but the spread sheet gave the glider's drag as 9.97 kg and the force needed to haul my 280 kg Libelle up a 5.67 degree slope at 60kts as 27.65 kg. Yeah, I know, I should have only kept 1 decimal point: 2 decimals is spurious accuracy. Of course, the other interesting number would be what fraction of the total drag of a climbing tug+glider combination was due to the glider. I suspect the glider is contributing less than Wg/Wt where Wg is the glider weight and Wt is the tow planes's weight. I'd expect the straight ratio to over-estimate the glider's contribution because it is likely to fly rather more efficiently than the tug. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
IF the glider is flown perfectly balanced in the perfect position behind
the tow plane and NEVER gets out of station or forms slack in the rope. ![]() Tom At 00:22 14 November 2013, Bob Cook wrote: yes, I underestimated.... Say a 800 lb glider at 40:1 L/D so the drag is about 20 lbs...but the tension component in the rope due to the climb angle (say 10:1) is going to be 80lbs....so you've got 100 lb tension on the rope. But a rope "in spec" would offer a safety factor of 6x up to 16x. Some tow planes can climb better than that...so more tension... Cookie At 23:46 13 November 2013, Martin Gregorie wrote: On Tue, 12 Nov 2013 18:43:41 -0800, Cookie wrote: My rough calculations show that the "normal" tension on a tow rope in smooth tow is very low...It is basically the drag on the glider, plus a tiny bit extra due to the climb vector...so maybe 60 lbs tension... I think its a bit more than that, but not much. Some time ago I did a fairly detailed spreadsheet calculation for my Libelle being towed at 60 kts in a 600 fpm climb and got a total rope tension of 37.62 kg, which was more or less what I'd guestimated from a mental round number calculation. The makeup of the rope tension did surprise me though: like you I thought drag would be the major part of it, but the spread sheet gave the glider's drag as 9.97 kg and the force needed to haul my 280 kg Libelle up a 5.67 degree slope at 60kts as 27.65 kg. Yeah, I know, I should have only kept 1 decimal point: 2 decimals is spurious accuracy. Of course, the other interesting number would be what fraction of the total drag of a climbing tug+glider combination was due to the glider. I suspect the glider is contributing less than Wg/Wt where Wg is the glider weight and Wt is the tow planes's weight. I'd expect the straight ratio to over-estimate the glider's contribution because it is likely to fly rather more efficiently than the tug. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
![]() Of course! Dynamic forces could be many times the static forces...in fact all the way up to the limit of the rope! Again good reason for an upper limit on the rope. Cookie At 01:34 14 November 2013, Tom Claffey wrote: IF the glider is flown perfectly balanced in the perfect position behin the tow plane and NEVER gets out of station or forms slack in the rope. ![]() Tom At 00:22 14 November 2013, Bob Cook wrote: yes, I underestimated.... Say a 800 lb glider at 40:1 L/D so the drag is about 20 lbs...bu the tension component in the rope due to the climb angle (say 10:1) is going to be 80lbs....so you've got 100 lb tension on the rope. But a rope "in spec" would offer a safety factor of 6x up to 16x. Some tow planes can climb better than that...so more tension... Cookie At 23:46 13 November 2013, Martin Gregorie wrote: On Tue, 12 Nov 2013 18:43:41 -0800, Cookie wrote: My rough calculations show that the "normal" tension on a tow rope in smooth tow is very low...It is basically the drag on the glider, plu a tiny bit extra due to the climb vector...so maybe 60 lbs tension... I think its a bit more than that, but not much. Some time ago I did a fairly detailed spreadsheet calculation for my Libelle being towed at 6 kts in a 600 fpm climb and got a total rope tension of 37.62 kg, which was more or less what I'd guestimated from a mental round number calculation. The makeup of the rope tension did surprise me though: like you I thought drag would be the major part of it, but the spread sheet gave the glider's drag as 9.97 kg and the force needed to haul my 280 kg Libelle up a 5.67 degree slope at 60kts as 27.65 kg. Yeah, I know, I should have only kept 1 decimal point: 2 decimals is spurious accuracy. Of course, the other interesting number would be what fraction of the total drag of a climbing tug+glider combination was due to the glider. suspect the glider is contributing less than Wg/Wt where Wg is th glider weight and Wt is the tow planes's weight. I'd expect the straight ratio to over-estimate the glider's contribution because it is likely to fly rather more efficiently than the tug. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
long range aircraft flying short-range routes? | tupolev204 | Piloting | 10 | April 22nd 11 07:44 PM |
FAA Administrator and FAA on the ropes and going broke | PapaFoxTrot | Piloting | 0 | September 16th 08 03:33 PM |
Charging system failure cuts short a long X-Country | Ron Lee[_2_] | Piloting | 10 | November 15th 07 11:04 PM |
Tow Ropes | [email protected] | Soaring | 6 | July 15th 05 07:39 PM |
Plasma Ropes ----- Help | Dave Martin | Soaring | 7 | September 30th 03 11:23 PM |
