I would never tow a trailer with the spare wheel stowed under
the trailer by the axle again -or if I had to I would take a set of axle stands. I had that arrangement on a trailer that had a flat tyre when I was towing it solo. It sank down so that there was insufficient vertical room to access and drop the spare wheel down. I had to jack the trailer up and go under it to undo the rusted securing nut by the side of the road with the trailer above me swaying about as trucks etc went by. It was not particularly enjoyable. John Galloway At 17:30 27 November 2013, rlovinggood wrote: Scott, Provide method of securing empty fuselage and wing dollies so they won't ro= ll around in an empty trailer during a retrieve. Someone else mentioned spare tire, but make it easy to get the spare tire o= ut and the flat tire back into the trailer. My spare is located under the = trailer behind the axle. It's "okay" to remove, but a real tough chore to = remount. The 15" steel rim and tire are HEAVY. I've thought about making = the "hoist" type of arrangement that some pickup trucks have for their spar= es. Don't skimp on the size of the front cargo door. The newer Cobras have lar= ge doors. Older trailers have smaller doors. Go big! Ray |
On Wednesday, November 27, 2013 12:35:59 PM UTC-7, John Galloway wrote:
I would never tow a trailer with the spare wheel stowed under the trailer by the axle again -or if I had to I would take a set of axle stands. I had that arrangement on a trailer that had a flat tyre when I was towing it solo. It sank down so that there was insufficient vertical room to access and drop the spare wheel down. I had to jack the trailer up and go under it to undo the rusted securing nut by the side of the road with the trailer above me swaying about as trucks etc went by. It was not particularly enjoyable. John Galloway At 17:30 27 November 2013, rlovinggood wrote: Scott, Provide method of securing empty fuselage and wing dollies so they won't ro= ll around in an empty trailer during a retrieve. Someone else mentioned spare tire, but make it easy to get the spare tire o= ut and the flat tire back into the trailer. My spare is located under the = trailer behind the axle. It's "okay" to remove, but a real tough chore to = remount. The 15" steel rim and tire are HEAVY. I've thought about making = the "hoist" type of arrangement that some pickup trucks have for their spar= es. Don't skimp on the size of the front cargo door. The newer Cobras have lar= ge doors. Older trailers have smaller doors. Go big! Ray Yes, what John and Ray said to watch out for is important. With the tire under the trailer and behind the axe it's really a pain getting it back up. I use my small jack and after lifting the tire up, side the jack under it, then jack it up to hold it in position while securing it again. If you can make room inside the trailer for the tire, might be the best way to carry that spare. My ASW 27 trailer held the spare in front of the nose cone hold and came that way from Cobra. |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
F.S. 3-glider trailer | Nigel Pocock | Soaring | 0 | September 29th 06 11:29 AM |
glider trailer Q | Ken Ward | Soaring | 10 | August 28th 06 04:27 PM |
glider trailer Q | Steve Leonard | Soaring | 1 | August 28th 06 05:29 AM |
RSS feed for glider flying related news and features? | Matthieu | Soaring | 0 | November 16th 05 06:05 PM |
