FS: Eccentric Assembly Tools
Old December 11th 13, 05:47 PM posted to rec.aviation.soaring
Soartech
Default FS: Eccentric Assembly Tools
The tool is hard and the bushing is relatively soft? How is this tool not a reamer?
The tool is made of a metal which is much softer than the sintered bronze bushings used commonly in spar pin holes.
I have one and it helps some. I am still rather ****ed that I usually have to ask for some big guy with huge arms to put the pins in. There must be some secret to this step.
Old December 11th 13, 07:27 PM posted to rec.aviation.soaring
Dave Nadler
Say WHAT ? 4 different vendors I know all use plastic.
It's very, very technical:
Line up the wings prior trying to insert the pins.
Look inside the holes and make sure they are lined up !
Adjust by height of fuselage and/or wings.
BEFORE trying to jam in the pins.
These tools are only useful if the wings are close
to properly aligned, and especially to pull the wings
together the last little bit.
Hope that helps,
Best Regards, Dave
PS: Use of incorrect grease (or none, or dirt) will
also make inserting the pins extremely hard...
Old December 11th 13, 10:44 PM posted to rec.aviation.soaring
son_of_flubber
On Wednesday, December 11, 2013 2:27:05 PM UTC-5, Dave Nadler wrote:
The tool is made of a metal?
So the plastic deforms to the shape of the bushing and spreads out the load.
Old December 12th 13, 02:53 AM posted to rec.aviation.soaring
SteveB_Z5
In a past thread about these tools I remember someone saying they had a metal tool. The tools I make are made of Delrin plastic.
From McMaster-Carr:
Wear- and Water-Resistant
Delrin® Acetal Resin
Considered the workhorse of plastics, Delrin® acetal resin combines moisture resistance and a slippery, wear-resistant surface with an ability to hold tight tolerances. Often used for gears, bushings, impellers, and other parts that require its strength and rigidity.
I have used one of these tools in well over 250 assemblies of my DG-200 with no sign of wear in the bushings.
Steve Z5
http://www.z5mfg.com/
Old December 12th 13, 06:01 PM posted to rec.aviation.soaring
Soartech
OK, I stand corrected. I thought mine was aluminum. It must be a very hard plastic.
Dave, what is the "correct" type of grease to use?
Old December 12th 13, 08:02 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Not Dave, but "clean" grease is the correct type to use. :-)
Opinions vary. Some sort of white lithium grease it probably best. I have used just plain vaseline, and have also seen it act more like glue than grease when trying to assemble a plane on a cold day. The guy I got one plane from swore that STP was the best wing pin lube. Yes, the stuff that Richard Petty use to push.
Steve Leonard
Old December 12th 13, 09:00 PM posted to rec.aviation.soaring
JS
Yes, some snow outside.
Look at INOX MX4 "Lanox" lanolin lubricant.
http://www.inoxmx.com/inox/mx4-lubricant/
Your local Harley shop may carry INOX products.
Or as suggested white lithium, available everywhere.
Old December 13th 13, 12:24 AM posted to rec.aviation.soaring
Dave Nadler
Opinions vary.
Of course, this is RAS ;-)
I used to use white lithium...
Advantage: really easy to see if its clean.
Disadvantage: less "slippery" than some other greases,
does tend to cake up.
more like glue than grease...
Right, not recommended.
I'm not sure what I'm using now: Lange provides good grease
in a big syringe in the pouch that holds the pins. It lasted
for assemblies for 900 hours of flying, then they gave me a new
syringe. I'll make sure its provided to you with your new Antares.
The synthetics like Superlube are really good.
See ya, Dave "YO electric"
Old December 16th 13, 06:30 PM posted to rec.aviation.soaring
Soartech
Thanks. I've been using Permatex white lithium grease. Back to the gym this winter.
Old December 12th 13, 11:40 PM posted to rec.aviation.soaring
son_of_flubber
Figure out what movements the pin insertion requires and design some specific exercises with dumbbells and rubber bands that specifically mimic those movements. I had difficulty manipulating my horizontal stabilizer above my head, but some simple exercises with dumbbells fixed that(my glider has an unusually large stabilizer that catches the wind).
FS: ECCENTRIC ASSEMBLY TOOLs SteveB_Z5 Soaring 17 March 22nd 13 07:40 PM
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 July 27th 12 11:52 PM
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 January 21st 12 05:37 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
