On Wednesday, December 11, 2013 12:47:30 PM UTC-5, Soartech wrote:
The tool is made of a metal Say WHAT ? 4 different vendors I know all use plastic. I usually have to ask for some big guy with huge arms to put the pins in. There must be some secret to this step. It's very, very technical: Line up the wings prior trying to insert the pins. Look inside the holes and make sure they are lined up ! Adjust by height of fuselage and/or wings. BEFORE trying to jam in the pins. These tools are only useful if the wings are close to properly aligned, and especially to pull the wings together the last little bit. Hope that helps, Best Regards, Dave PS: Use of incorrect grease (or none, or dirt) will also make inserting the pins extremely hard... |
On Wednesday, December 11, 2013 2:27:05 PM UTC-5, Dave Nadler wrote:
The tool is made of a metal? Say WHAT ? 4 different vendors I know all use plastic. So the plastic deforms to the shape of the bushing and spreads out the load. |
In a past thread about these tools I remember someone saying they had a metal tool. The tools I make are made of Delrin plastic.
From McMaster-Carr: Wear- and Water-Resistant Delrin® Acetal Resin Considered the workhorse of plastics, Delrin® acetal resin combines moisture resistance and a slippery, wear-resistant surface with an ability to hold tight tolerances. Often used for gears, bushings, impellers, and other parts that require its strength and rigidity. I have used one of these tools in well over 250 assemblies of my DG-200 with no sign of wear in the bushings. Steve Z5 http://www.z5mfg.com/ On Wednesday, December 11, 2013 2:44:13 PM UTC-8, son_of_flubber wrote: On Wednesday, December 11, 2013 2:27:05 PM UTC-5, Dave Nadler wrote: The tool is made of a metal? Say WHAT ? 4 different vendors I know all use plastic. So the plastic deforms to the shape of the bushing and spreads out the load. |
![]() PS: Use of incorrect grease (or none, or dirt) will also make inserting the pins extremely hard... OK, I stand corrected. I thought mine was aluminum. It must be a very hard plastic. Dave, what is the "correct" type of grease to use? |
On Thursday, December 12, 2013 12:01:11 PM UTC-6, Soartech wrote:
Dave, what is the "correct" type of grease to use? Not Dave, but "clean" grease is the correct type to use. :-) Opinions vary. Some sort of white lithium grease it probably best. I have used just plain vaseline, and have also seen it act more like glue than grease when trying to assemble a plane on a cold day. The guy I got one plane from swore that STP was the best wing pin lube. Yes, the stuff that Richard Petty use to push. Steve Leonard |
Yes, some snow outside.
Look at INOX MX4 "Lanox" lanolin lubricant. http://www.inoxmx.com/inox/mx4-lubricant/ Your local Harley shop may carry INOX products. Or as suggested white lithium, available everywhere. Jim |
On Thursday, December 12, 2013 3:02:28 PM UTC-5, Steve Leonard wrote:
On Thursday, December 12, 2013 12:01:11 PM UTC-6, Soartech wrote: Dave, what is the "correct" type of grease to use? Opinions vary. Of course, this is RAS ;-) Some sort of white lithium grease it probably best. I used to use white lithium... Advantage: really easy to see if its clean. Disadvantage: less "slippery" than some other greases, does tend to cake up. I have used just plain vaseline, and have also seen it act more like glue than grease... Right, not recommended. I'm not sure what I'm using now: Lange provides good grease in a big syringe in the pouch that holds the pins. It lasted for assemblies for 900 hours of flying, then they gave me a new syringe. I'll make sure its provided to you with your new Antares. The synthetics like Superlube are really good. See ya, Dave "YO electric" |
Thanks. I've been using Permatex white lithium grease. Back to the gym this winter.
FS: ECCENTRIC ASSEMBLY TOOLs | SteveB_Z5 | Soaring | 17 | March 22nd 13 07:40 PM |
FS: Eccentric Assembly Tools | SteveB_Z5 | Soaring | 0 | July 27th 12 11:52 PM |
FS: Eccentric Assembly Tools | SteveB_Z5 | Soaring | 0 | January 21st 12 05:37 PM |
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:45 AM |
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:45 AM |
