Glareshield mounted compass?
Old March 9th 14, 04:40 PM posted to rec.aviation.soaring
mike
Default Glareshield mounted compass?
On Sunday, March 9, 2014 9:46:46 AM UTC-6, Dan Marotta wrote:
Use aluminum or fiberglass, not any steel in your fabrication.
"Echo" wrote in message
Anyone have any experience modifying the glareshield for a partially
embedded compass? I have a brand new airpath panel mount, but would like
the panel space for a transponder, flarm, something more productive.
Ideally would prefer to swap my airpath for something I could mount somehow
half set into the glareshield, then line the whole game with black felt.
Thoughts?
Jordan
ASW20 E
Black felt will stop some glare on the glare shield, so does flat black paint. I have a pedestal mount compass towards the front of the glare shield in my Mini Nimbus, and it works well.
Old March 9th 14, 10:07 PM posted to rec.aviation.soaring
son_of_flubber
If you need magnetic shielding and you want to save a few bucks, scavenge the sheet metal case of an old harddrive. It has a nickel rich alloy that blocks magnetic fields generated by your DC power and vario step motors etc... Put the shield around the offending item, or between the item and the compass. Aircraft Spruce also sells unblemished sheets of the this material.
Old March 9th 14, 10:47 PM posted to rec.aviation.soaring
kirk.stant
I'm totally with Steve Koerner on this one - Sticking a useless piece of 18th century hardware on the glareshield where it obstructs the field of view forward is ridiculous and potentially dangerous.
Seriously, have you EVER navigated using your mag compass as the primary nav instrument?
In my LS6, a compass on the glareshield will completely block my view of the towplane when in normal high tow. It was the first thing I pitched when I got the glider. I replaced it (to keep the A&Ps happy) with a small PZL ball compass tucked in a corner of the instrument panel. It has now been moved due to the mounting of a PFlarm butterfly display in it's prized bit of panel real estate, and will be relocated in the shade behind my Oudie; so when the end of the world happens and all the GPS satellites fall out of the sky I can still pretend to navigate (until the earth's magnetic field switches again - it's due).
Another good place to put it is in the side map pocket - then you can pull it out and admire it when needed. Very retro, and all...
Kirk
66
Old March 10th 14, 01:38 AM posted to rec.aviation.soaring
son_of_flubber
I have my backup backup compass back behind the seat back in my landout kit. A compass is the best tool if you ever need to bushwhack in dense woods.
Old March 13th 14, 06:04 AM posted to rec.aviation.soaring
Echo
It's part of my manufacturer issued type certificate as well as a part 91 reg. As a professional pilot, I just assume not hang my livelihood out there with some hokie backup compass. That being said, I agree that it's useless with the exception of a very few scenarios. I do love the DC9 series compass. So much swing error that it has to be mounted on the aft cockpit bulkhead. Seen it many times. Awesome. Incredible that thing was designed looking at slide rules through thick glasses before we even engineered the Lunar Lander. What a TANK.
Jordan
E
Old March 14th 14, 12:18 PM posted to rec.aviation.soaring
kirk.stant
Understood - which is why I still have an aviation compass in my cockpit - but I refuse to be less safe (reduced visibility) to satisfy some bogus FAR requirement. So I found the smallest certified aircraft compass (the little PZL KI-13A) that I could mount in an inconspicuous location on my panel.
Sometimes, it's the little things in life...
Kirk
66
Old March 20th 14, 06:59 PM posted to rec.aviation.soaring
Brian[_1_]
Jordan
E
I agree with that you must comply with the manufacturers type certificate, but I can't seem to the find any part 91 regs that require one for glider?
Brian
Old March 21st 14, 01:57 AM posted to rec.aviation.soaring
Echo
Glider=aircraft unless the SSA pulled a waiver from the FAA for that too...
mounting a PCAS on the glareshield Mike Noel Owning 0 October 1st 08 04:49 PM
PA-28 Glareshield Replacement Marco Leon[_4_] Owning 8 January 11th 08 08:33 PM
Glareshield Overhaul? Mike Spera Owning 7 March 23rd 07 11:34 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
Glareshield renewal and TSA Roger Long Owning 9 February 27th 04 12:39 PM
