Bastoune wrote:
While finalizing the installation of a TRIG TT21 transponder, I am running into less that consistent information regarding the ground plane spec. for the antenna. The plan at this point is to use a RAMI AV-22 rod antenna inside the fiberglass fuselage. The TRIG TT21 Manual has this to say about the dimension of the ground plane: "[...] As the ground plane is made smaller, the actual dimensions of the ground plane become more critical, and small multiples of the wavelength should be avoided, as should circles. Rectangles or squares are much less likely to create a critical dimension that resonates with the transmissions. The smallest practical ground plane is a SQUARE around 120mm per side; as the size increases the performance may actually get worse, but will be better by the time the ground plane is 700mm on each side." From the Cumulus Soaring site, RAMI, the antenna manufacturer reportedly states that "The smallest recommended ground plane would be 12 inches in diameter (305mm)." Now, when I look at all of the Schleicher TNs, I see that they call out in most case a 130mm ROUND aluminum disk to be used in conjunction with the RAMI antenna mentioned above. So what gives? Round or Square? Short of a very large plane, what dimension to use for the ground plane? The fact that the information available does not seem to converge on a given dimension or shape for a ground plane tells me that this is probably more than one "OK" answer. Thanks, B Does your glider manufacturer have a TN or similar for a transponder install in this or a similar glider ? if so just follow those directions. Ground planes are usually better off on the larger side and round. If making this up a fuselage internal antenna install yourself you *might* be better off with a dipole antenna that does not need a ground plane. The Schleicher TN ground plane diameters are often limited by internal clearance, however again you should follow the glider manufacturers directions if they exist. There are reasons that an external antenna install may be preferred to an internal one. It is fantastic that you are installing a transponder, but I get nervous with questions like this, if you are having to ask these questions are there other things as well you are overlooking or misunderstanding? it is a great idea if you can to have an experienced glider A&P or knowledgable person check on your plans well before you start the install. Darryl |
When I installed my TT22, I made an aluminum square, 120mm on the side, and
curved it to fit the inside of my fuselage aft of the landing gear. ATC has no problem seeing me. "Darryl Ramm" wrote in message ... Bastoune wrote: While finalizing the installation of a TRIG TT21 transponder, I am running into less that consistent information regarding the ground plane spec. for the antenna. The plan at this point is to use a RAMI AV-22 rod antenna inside the fiberglass fuselage. The TRIG TT21 Manual has this to say about the dimension of the ground plane: "[...] As the ground plane is made smaller, the actual dimensions of the ground plane become more critical, and small multiples of the wavelength should be avoided, as should circles. Rectangles or squares are much less likely to create a critical dimension that resonates with the transmissions. The smallest practical ground plane is a SQUARE around 120mm per side; as the size increases the performance may actually get worse, but will be better by the time the ground plane is 700mm on each side." From the Cumulus Soaring site, RAMI, the antenna manufacturer reportedly states that "The smallest recommended ground plane would be 12 inches in diameter (305mm)." Now, when I look at all of the Schleicher TNs, I see that they call out in most case a 130mm ROUND aluminum disk to be used in conjunction with the RAMI antenna mentioned above. So what gives? Round or Square? Short of a very large plane, what dimension to use for the ground plane? The fact that the information available does not seem to converge on a given dimension or shape for a ground plane tells me that this is probably more than one "OK" answer. Thanks, B Does your glider manufacturer have a TN or similar for a transponder install in this or a similar glider ? if so just follow those directions. Ground planes are usually better off on the larger side and round. If making this up a fuselage internal antenna install yourself you *might* be better off with a dipole antenna that does not need a ground plane. The Schleicher TN ground plane diameters are often limited by internal clearance, however again you should follow the glider manufacturers directions if they exist. There are reasons that an external antenna install may be preferred to an internal one. It is fantastic that you are installing a transponder, but I get nervous with questions like this, if you are having to ask these questions are there other things as well you are overlooking or misunderstanding? it is a great idea if you can to have an experienced glider A&P or knowledgable person check on your plans well before you start the install. Darryl |
Transponder Antenna Ground Planes | Ken Kochanski (KK) | Soaring | 6 | April 6th 07 08:13 PM |
Glide Slope Antenna Ground Plane | JKimmel | Home Built | 6 | August 1st 06 01:28 AM |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Antenna ground plane and coax grounding | G. Fred McCutchen | Home Built | 2 | August 8th 04 12:27 PM |
Antenna Ground Plane Grounding | Fastglasair | Home Built | 1 | July 8th 03 05:21 PM |
