Really...why do you have to make this so complicated?
Get an L-2. Providing you have a pure fiberglass fuselage just slap it on the inside of the fuse and be happy. I have an LS-8. The L-2 is on the side of the fuse behind the wheel. Air traffic control radar reads me just fine no matter what my orientation to the radar. Commercial aircraft that are above me read me no matter what our relative orientations. |
On Wednesday, March 19, 2014 6:34:12 AM UTC-7, wrote:
Really...why do you have to make this so complicated? Get an L-2. Providing you have a pure fiberglass fuselage just slap it on the inside of the fuse and be happy. I have an LS-8. The L-2 is on the side of the fuse behind the wheel. Air traffic control radar reads me just fine no matter what my orientation to the radar. Commercial aircraft that are above me read me no matter what our relative orientations. "Providing you have a pure fiberglass fuselage" Need I say more? |
Thanks for the info. An A&P & experienced avionic installation centre will be doing the install and xpdr test so it will be their call at the end. I am just trying to understand why there are varying ground plane recommendations between the trig manual, RAMI antenna mfr and what Scheichler typically recommends. Mpa-Thank you for the explanation. I know understand a bit better the trade-offs in the ground plane sizes. I saw the L-2 antenna. Seems nice.
Don't let them cut your fiberglass, use the internal dipole described earlier glued/velcroed to an internal verticle brace. We did that for an Ls4, Grob 103 and Grob 104.
BT |
On Monday, March 24, 2014 8:37:57 PM UTC-7, Bill T wrote:
Don't let them cut your fiberglass... That's all well and good if it is indeed fiberglass. I can't remember if the original poster said what their fuselage is made of. But if it's carbon fiber, an internal antenna will not work because of the opacity of carbon to radio waves. With carbon fuselages, you have to either put the antenna somewhere that isn't carbon (sometimes the fin and/or rudder are made with radio-transparent fiberglass or aramid fibers), or you must install an external antenna. With my gliders, the fuselage and fin is made with carbon, but we put the com antenna in the aramid fiber rudder. We haven't installed any transponder antennas yet, but when we do we'll probably just install an external blade antenna and call it good. Thanks, Bob K. |
Transponder Antenna Ground Planes | Ken Kochanski (KK) | Soaring | 6 | April 6th 07 08:13 PM |
Glide Slope Antenna Ground Plane | JKimmel | Home Built | 6 | August 1st 06 01:28 AM |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Antenna ground plane and coax grounding | G. Fred McCutchen | Home Built | 2 | August 8th 04 12:27 PM |
Antenna Ground Plane Grounding | Fastglasair | Home Built | 1 | July 8th 03 05:21 PM |
