Stick grip loose - help how do I attach it properly?
Old March 26th 14, 04:23 PM posted to rec.aviation.soaring
Dan Marotta
Default Stick grip loose - help how do I attach it properly?
Dish soap also works to lubricate and dries sticky. Not good on a
motorcycle riding in the rain, however...
On Wednesday, March 26, 2014 2:27:04 AM UTC+1, Paul Villinski wrote:
The old trick for motorcycle handgrips is to spray the bar with
hairspray, then quickly slide the grip on. The spray lubes the bar so you
can get the grip on, then cements it in place once it dries. Bond is
strong enough to hold, but reversible....
Just wrap the stick with electrical tape think enough that you can slide
the grip on with a lot of force. If you apply the right thickness of tape,
it will hold on very good, and is removable anytime with some turning and
pulling.
Old March 26th 14, 06:29 PM posted to rec.aviation.soaring
TravisBrown73[_2_]
I had good luck w/ drywall tape (the mesh-kind) on our 102.
The tape is sticky on both sides and has enough thickness to only need one wrap on the stick to get the grip to not move. Getting the grip on was a little problematic...but it's not going anywhere, and could be undone if necessary.
~Travis
Old March 28th 14, 02:38 PM posted to rec.aviation.soaring
Craig R.
Yikes! Aren't any of you guys golfers? :P
Use double sided golf re-gripping tape (eg. http://www.golfsmith.com/cm/search/gripping-supplies ). Spiral the tape down the stick for the length of the grip. Butt the sides of the tape up as you go. Trim accordingly. If one layer isn't thick enough, continue to layer until it is. Get a can of cigarette lighter fluid. After properly protecting the cockpit surfaces, douse the tape and the inside of the grip with the lighter fluid so all contacting surfaces are really wet. Quickly slide the grip on the stick and position it properly immediately. The lighter fluid will evaporate within maybe 20 seconds, so be quick and accurate. You only get one shot so do it right or you will be cutting off the grip and trying again.
Old March 28th 14, 02:44 PM posted to rec.aviation.soaring
Andrew Brayer
no, we're soaring junkies... there's no golfing on the airport!
Old March 28th 14, 04:03 PM posted to rec.aviation.soaring
Two Shoes (Judson Knowles)
They also make water soluble too, if you don't want to use lighter fluid.
LS-4 Trim Lock coming loose with stick deflection? gs03jsa Soaring 9 September 19th 11 09:44 PM
ME109 Stick Grip for sale Chris Jamesson Military Aviation 4 August 12th 10 06:10 PM
control stick (complete not only grip) from mig-21 papcio Aviation Marketplace 0 May 3rd 04 07:08 PM
B-8 stick grip buttons B2431 Military Aviation 4 December 16th 03 10:15 AM
FA Infinity Military Style Control Stick Grip Terry Ladouceur Home Built 3 October 8th 03 12:52 AM
