B-8 stick grip buttons
Old December 14th 03, 10:44 PM
B2431
Default B-8 stick grip buttons
What are the middle and lower buttons on the B-8 stick grip used for?
I used to know, but senility seems to have set in.
Dan, U. S. Air Force, retired
Old December 15th 03, 03:56 AM
Paul Hirose
Stick grip button functions depend on the plane. The B-2 bomber has
B-8 stick grips but doesn't use the angled button on the left side.
The "pinkie switch" at the bottom front of the grip, when held in,
activates high gain nosewheel steering for making sharp turns at low
speed.
In flight it does something else. A momentary press interrupts the
autopilot roll axis. The autopilot remains coupled in roll, but only
in stick-steering mode. (I.e., left/right movement of the stick
controls bank angle. When you center the stick the autopilot maintains
that bank angle.) Pressing the button again restores roll guidance,
e.g., the autopilot tracks an ILS localizer beam or TACAN radial.
The F-5E used the side button on the stick as a "dogfight switch". The
pinkie switch activated nosewheel steering on the ground. In the air,
it was a microphone switch to supplement the one on the throttle.
I think the F-86D controlled its nosewheel steering the same way, but
the side button keyed the radio.
I once looked into getting a B-8 grip to mount on a plaque for a
maintenance troop who was retiring. Occasionally the grips do fail and
have to be replaced. But unfortunately, they aren't throwaway items,
at least the ones on the B-2 bomber. When you get a new one from
Supply, you have to give them the bad one, or there will be hell to
pay. More specifically, about $4400.
Paul Hirose
To reply by email delete INVALID from address.
Old December 15th 03, 05:14 AM
B2431
speed.
Paul Hirose
They are available for a couple hundred dollars on e-bay. The reason for having
to turn them in was they were high pilferage items like the 8 day clocks (also
available on e-bay).
On the F-4E I think the pinkie switch was for nose wheel steering IIRC.
I have seen stick grips with the switch labels engraved. For the life of me I
can't recall which ones though. I'm tempted to say the F-80 was one.
Dan, U.S. Air Force, retired
Old December 16th 03, 09:35 AM
Dweezil Dwarftosser
Yes. (Heat Mx)Cool Start/IFR door halfway down on the left.
control stick (complete not only grip) from mig-21 papcio Aviation Marketplace 0 May 3rd 04 07:08 PM
post vs stick hangar construction Joa Home Built 25 November 1st 03 01:03 PM
FA Infinity Military Style Control Stick Grip Terry Ladouceur Home Built 3 October 8th 03 12:52 AM
The F-16 control stick? Christopher Military Aviation 13 September 22nd 03 10:18 AM
RAC grip (Formerly MAC) Ed Wischmeyer Home Built 7 August 26th 03 03:44 PM
