On Thursday, March 27, 2014 1:19:20 PM UTC-6, kiwiindenver wrote:
On Thursday, March 27, 2014 12:27:35 PM UTC-6, JS wrote: Cool. It currently is not displaying numbers in the airport ID. Perhaps a "pro" version could include the ability to input Lat/Lon with a couple of user-created shortcuts? Nice job, Jim My validation code is stripping the number. I will add some Lat/Long validation so either will work. I have just published a new version that has initial support for Lat/Long. I will improve this later. This version is a quick fix to get people up and running and hence help get more feedback. For now, enter a comma separated pair of decimal lat/long using negative for South and West. This is the same way you enter lat/long into the NOAA site. PS. It may take a few hours to push this version through the Google servers. |
Sweet. Being able to save and name "favorite" locations would be great.
It seems like there is some round up on the ground elevation? When I put KHUT, Hutchinson, KS, in it has the base altitude at 2000 ft when it should be more like 1600. Also looks like the default time is 8 am to 7 pm. That's OK but I think by this time of the day the Op40 should be able to forecast to tomorrow morning which would be nice. Perhaps you could have it start at 8 am of the current day and go out as far as the forecast is available? Next of course will be to include the other models... I really like this presentation and thinking will come in really handy. |
On Thursday, March 27, 2014 6:12:02 PM UTC-6, Tony wrote:
Sweet. Being able to save and name "favorite" locations would be great. It seems like there is some round up on the ground elevation? When I put KHUT, Hutchinson, KS, in it has the base altitude at 2000 ft when it should be more like 1600. Also looks like the default time is 8 am to 7 pm. That's OK but I think by this time of the day the Op40 should be able to forecast to tomorrow morning which would be nice. Perhaps you could have it start at 8 am of the current day and go out as far as the forecast is available? Next of course will be to include the other models... I really like this presentation and thinking will come in really handy. Thanks for that feedback. I'll take a look at those problems. Your right about the time, I set those limits thinking it would easily cover most soaring needs. I'll do some more investigation to see what data is available for download. How many favourites do you think you would want? How many would you use regularly? How many would you use once in a blue moon? How important are the other models? Would this be a set & forget item or something you change regularly? |
I tried to use the identifier for Moriarty, NM, K0E0, and get the error,
[Failed to load KE!]. Does the program not accept numerals (zero) in the identifier? Still working on the conversion to decimal Lat/Lon... "kiwiindenver" wrote in message ... On Thursday, March 27, 2014 6:12:02 PM UTC-6, Tony wrote: Sweet. Being able to save and name "favorite" locations would be great. It seems like there is some round up on the ground elevation? When I put KHUT, Hutchinson, KS, in it has the base altitude at 2000 ft when it should be more like 1600. Also looks like the default time is 8 am to 7 pm. That's OK but I think by this time of the day the Op40 should be able to forecast to tomorrow morning which would be nice. Perhaps you could have it start at 8 am of the current day and go out as far as the forecast is available? Next of course will be to include the other models... I really like this presentation and thinking will come in really handy. Thanks for that feedback. I'll take a look at those problems. Your right about the time, I set those limits thinking it would easily cover most soaring needs. I'll do some more investigation to see what data is available for download. How many favourites do you think you would want? How many would you use regularly? How many would you use once in a blue moon? How important are the other models? Would this be a set & forget item or something you change regularly? |
Made the conversion, looks nice. Now I need to review how to use the Skew-T
chart. "Dan Marotta" wrote in message ... I tried to use the identifier for Moriarty, NM, K0E0, and get the error, [Failed to load KE!]. Does the program not accept numerals (zero) in the identifier? Still working on the conversion to decimal Lat/Lon... "kiwiindenver" wrote in message ... On Thursday, March 27, 2014 6:12:02 PM UTC-6, Tony wrote: Sweet. Being able to save and name "favorite" locations would be great. It seems like there is some round up on the ground elevation? When I put KHUT, Hutchinson, KS, in it has the base altitude at 2000 ft when it should be more like 1600. Also looks like the default time is 8 am to 7 pm. That's OK but I think by this time of the day the Op40 should be able to forecast to tomorrow morning which would be nice. Perhaps you could have it start at 8 am of the current day and go out as far as the forecast is available? Next of course will be to include the other models... I really like this presentation and thinking will come in really handy. Thanks for that feedback. I'll take a look at those problems. Your right about the time, I set those limits thinking it would easily cover most soaring needs. I'll do some more investigation to see what data is available for download. How many favourites do you think you would want? How many would you use regularly? How many would you use once in a blue moon? How important are the other models? Would this be a set & forget item or something you change regularly? |
Yes I currently strip numerals. I will fix that for you.
skew-t access | Peter von Tresckow | Soaring | 5 | October 10th 13 09:02 PM |
Android XC Soar | Paul Besing | Soaring | 3 | May 3rd 11 09:39 PM |
XCSoar for Android | Sean Fidler | Soaring | 6 | March 21st 11 05:50 PM |
Android App | Mike[_36_] | Soaring | 8 | July 14th 10 10:53 AM |
Skew-T charts on Dr. Jacks ? | Doug Snyder | Soaring | 3 | April 25th 05 07:36 PM |
