Handicap Task Software
Old March 28th 14, 05:10 PM posted to rec.aviation.soaring
Soartech
Default Handicap Task Software
Jim, I don't see anywhere in the program that you may enter your glider type. How to you provide a handicap without this info?
Old March 28th 14, 05:24 PM posted to rec.aviation.soaring
Jim White[_3_]
The calculator program produces a task sheet for all handicaps that are
flying the task. The scoring software writes the task into the pilots
evidence file using the glider handicap and the barrel size for that
handicap calculated before hand.
The pilot simply has to read off the barrel size he must fly against his
handicap on the task sheet.
If you put a task into the software using a tp file of your choice, and hit
the calc button you will see the output. There is a sample in the help file
and a run through in the videos.
I hope that answers your question
Paragliding task score software [email protected] Soaring 5 July 12th 12 02:08 PM
handicap 5 ugly Soaring 1 November 26th 11 01:57 AM
How is handicap weight determined for the SSA handicap list? AK Soaring 1 September 25th 07 01:43 PM
SSA HANDICAP LIST [email protected] Soaring 11 September 17th 04 02:58 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 04:12 PM
