Paragliding task score software
Old July 11th 12, 06:40 PM posted to rec.aviation.soaring
Default Paragliding task score software
Hi,
I'd like to write a small programm (online) to evaluate our paragliding competitions. We usually set a couple of turnpoints with a radius of 400 meters and the aim is to pass all these one by one and fly to the target cylinder, the finish. Just to get an idea how it looks like, I made a small graphic:
http://dl.dropbox.com/u/15535011/PGC...auswertung.png
The flights a recorded a IGC Files which i can process line by line. I need to know if the pilot exited the start cylinder before a defined time and how many cylinders were passed correct. If a cylinder was entered i have to count the distance to the previous cylinder and if not I need to chip in the edge of 90 degrees to the nearest point to the next turnpoint. I hope you understand what I mean.
Does anybody know if such a software allready exists or how to do the computation (PHP or Perl prefered). I allready found some libraries for calculatin the distance but I don't know how to do the 90 degrees calculation.
Any hints will be helpfull!
Max
National 1-26 score posting hretting Soaring 0 June 27th 09 06:02 AM
Will Cambridge GPSNAV score in 2k6 OLC? Stewart Kissel Soaring 1 October 30th 05 06:52 PM
OLC score calculation? ttaylor at cc.usu.edu Soaring 4 August 24th 05 02:50 AM
Day 2 New Castle Score Sheet Guy Byars Soaring 3 September 25th 03 03:39 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 05:12 PM
