On Monday, 31 March 2014 15:21:12 UTC+13, Bill T wrote:
I can measure next weekend. There are 3 weights, the bottom of the 3 has rounded corners to fit the fusalge shape. Square corners would poke holes in the fiberglass. You'll also want the weight, the effect of each weight forward of your feet is the same as 11 pounds in the seat. BT Thank you. That Would be very much appreciated. I know the weight is 2.4kg. Cheers, Nick |
JSF/F-22 weights | John Cook | Military Aviation | 2 | September 11th 04 06:32 AM |
Lak-12 weights | pete83 | Soaring | 1 | June 26th 04 11:25 PM |
Lak-12 weights | pete83 | Soaring | 0 | June 26th 04 06:47 PM |
Can you mix oil weights? | Ben Jackson | Owning | 13 | January 5th 04 02:51 AM |
Engine weights | Salem Farm & Garden | Home Built | 5 | July 22nd 03 04:27 AM |
