Best way to connect US PowerFlarm to Dell Streak 5
Old July 1st 14, 10:38 PM posted to rec.aviation.soaring
Blake Seese
Default Best way to connect US PowerFlarm to Dell Streak 5
Can anyone tell me the best way to connect a PowerFlarm to a Dell
Streak 5?
Old July 2nd 14, 12:09 AM posted to rec.aviation.soaring
Paul Remde
Hi Blake,
One clean way would be to use a K6 Bt module.
http://www.cumulus-soaring.com/k6.htm#K6Bt
Which PowerFLARM are you using (Core or Portable)?
The PowerFLARM Core (not the Portable) has a DB-9 port with the same
connections as a Cambridge 302, so the cable in the link below can be used
to connect a K6 Bt to the Core. The Core will power the K6 Bt.
http://www.cumulus-soaring.com/godda...e-K6Bt-302-0.3
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_________________________________
"Blake Seese" wrote in message
Streak 5?
Dell Streak - what ROM version? [email protected] Soaring 7 May 24th 14 05:09 PM
Temperature Probe for Dell Streak Dan Marotta Soaring 14 April 20th 13 02:56 AM
Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more Evan Ludeman[_4_] Soaring 2 December 31st 12 12:14 AM
Dell Streak 5 available soartech[_2_] Soaring 0 November 14th 12 05:44 PM
Short review of the Dell Streak with XCSoar Max Kellermann Soaring 6 February 9th 11 04:22 PM
