On Wednesday, October 15, 2014 2:34:52 PM UTC-7, wrote:
I am working on a project to convert my L13 into an airshow bird for static display. I need the bearings that run in the flap tracks and the rod end bearings for the flaps/aileron control rods at the flying surface end... What I'd do is measure the ID, OD, and width of the bearings, and then look them up using the bearing search tool on www.VXB.com. The dimensions will most likely be integer millimeters. Thanks, Bob K. |
That may work. However the rod end bearings have a curved dimension around the circumference. I am not sure if these are pressed into the rod ends or if the entire rod end has to be replaced. I did not take this bird apart so putting it back together without a manual is tough. I really need a maintenance manual to educate myself.
Lane |
On Wednesday, October 15, 2014 6:26:52 PM UTC-7, wrote:
...I am not sure if these are pressed into the rod ends or if the entire rod end has to be replaced... If you can send me a photo of the assembly in question, I can probably give you some guidance. ...I did not take this bird apart so putting it back together without a manual is tough. I really need a maintenance manual to educate myself. You might try contacting Blanik America. I have had mediocre luck getting a response from them, but I haven't had opportunity to try for several years. It might be different now. Thanks, Bob K. |
On Wednesday, October 15, 2014 7:11:51 PM UTC-6, Bob Kuykendall wrote:
On Wednesday, October 15, 2014 2:34:52 PM UTC-7, wrote: I am working on a project to convert my L13 into an airshow bird for static display. I need the bearings that run in the flap tracks and the rod end bearings for the flaps/aileron control rods at the flying surface end... What I'd do is measure the ID, OD, and width of the bearings, and then look them up using the bearing search tool on www.VXB.com. The dimensions will most likely be integer millimeters. Thanks, Bob K. Another good source of bearing data is SKF. (www.skf.com) It's nice that they provide CAD drawing files of their bearings. Both metric and inch bearings are available. |
Hot wheel bearings | JJ Sinclair[_2_] | Soaring | 17 | June 19th 13 03:20 PM |
Avionic wheel bearings | cuflyer | Soaring | 6 | June 12th 13 12:57 PM |
Bearings 12 1/2 inch OD for Sale | keny | Aviation Marketplace | 0 | December 22nd 10 10:48 PM |
Blanik L-23 Super Blanik Manual -F.C.F.S. | Joel Flamenbaum | Soaring | 2 | April 14th 10 03:29 PM |
E2-C wheel bearings needed | CaptAro | Restoration | 1 | July 19th 03 04:32 AM |
