Hot wheel bearings
Old June 17th 13, 02:26 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Hot wheel bearings
Old June 17th 13, 02:42 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Monday, June 17, 2013 6:26:47 AM UTC-7, JJ Sinclair wrote:
I usually touch the Cobra wheel bearing caps and check the tires when gassing up. They have always been just warm, (maybe 150 degrees), but yesterday they were too hot to leave my finger on both bearings (maybe 200 degrees). After slowing down from 60 to town traffic speed of 35, they both felt cool again. Is this normal? I remember Cobra having problems with their sealed wheel bearings. Should I replace both bearings? The trailer is 1999 vintage with 10,000 + miles on it.
JJ
Old June 17th 13, 02:59 PM posted to rec.aviation.soaring
Jim White[_3_]
=20
gassi=
yesterday
degrees).
cool=
sealed
vintage=
JJ
More likely to be a problem with binding brakes. Unfortunately once you
cook the bearings it is often wise to replace them!
I always check that the brake housing is cool after driving for a mile or
so. You have to be careful slowing down though, otherwise they will heat
normally coming to a stop. I would think 150 degrees is much too hot any
way. I would expect more like ambient + 30 or so.
Old June 17th 13, 06:50 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
The surge brake has been lubricated and I can feel the brakes come on and then release as I apply tow vehicle braking. Trailer rolls easily when pushing it around by hand. Don't believe the brakes are causing overheating as the hot condition was noted after 3 hours of straight towing at freeway speeds with little or no breaking action, but the fact that both hubs were hotter than normal would seen to eliminate the chance of both bearings failing at the same time. I did notice the hot condition right after a rather steep descent into Susanville, Ca, so maybe the trailer brakes did heat things up during this descent. I'll check it again after some level ground towing.
Thanks for your input, I think we may have just figured it out.
JJ
Old June 17th 13, 11:10 PM posted to rec.aviation.soaring
son_of_flubber
So how hot does the assembly need to get before the lubrication is destroyed in a sealed wheel bearing?
Maybe something like this would be a useful accessory?
http://www.amazon.com/Taylor-Digital...on+thermometer
I always downshift and use the engine to brake the trailer, but the surge brake is probably kicking in on the steep grades.
Old June 18th 13, 07:24 AM posted to rec.aviation.soaring
bumper[_4_]
I live near the bottom of Kingsbury Grade at Minden. A friend brought his glider over to my house, coming down the grade (about 8.5 miles of 8% grade or so). The brakes on his new Cobra trailer were really hot, with a strong odor of burning brakes.
Not good, but I'd say normal.
bumper
Old June 18th 13, 09:39 AM posted to rec.aviation.soaring
Jim White[_3_]
grade
strong
bumper
Interestingly the Alko manual suggests that if the brakes are coming on
when going downhill or decelerating then the overrun damper is faulty.
Excerpt from manual:
BRAKES APPLY DURING
DECELERATION OR
DOWNHILL TRAVEL
Overrun damper is defective. Replace the overrun damper.
Old June 18th 13, 11:44 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
How does it do that? How know the difference between overrun caused by car deceleration, and that due to gravity?
(Not disputing, just interested in the engineering.)
Chris N
Old June 18th 13, 11:46 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
I meant during braking vs gravity or normal deceleration. C
Old June 18th 13, 12:35 PM posted to rec.aviation.soaring
Jim White[_3_]
try this
http://caravanchronicles.com/guides/...brake-systems/
Avionic wheel bearings cuflyer Soaring 6 June 12th 13 12:57 PM
cobra wheel bearings and brakes [email protected] Soaring 4 August 13th 12 11:21 PM
Repacking wheel bearings Ramy Soaring 2 June 12th 09 05:03 AM
Q about trailer wheel bearings Ken Ward Soaring 1 September 15th 06 02:40 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
