On Thursday, December 4, 2014 12:13:40 PM UTC-8, Nick Kennedy wrote:
http://www.nadler.com/sn10/Brozel_TE...n_20020510.pdf Here is some help Nick Thank you Nick, and thank you UH. I have also read in several references, including Reichmann, that the TE venturi pressure must be -1. I do not understand what this means. Can you explain this without heavy math? Thank you |
On Thursday, December 4, 2014 7:47:08 PM UTC-5, Jim Lewis wrote:
On Thursday, December 4, 2014 12:13:40 PM UTC-8, Nick Kennedy wrote: http://www.nadler.com/sn10/Brozel_TE...n_20020510.pdf Here is some help Nick Thank you Nick, and thank you UH. I have also read in several references, including Reichmann, that the TE venturi pressure must be -1. I do not understand what this means. Can you explain this without heavy math? Thank you This may help clarify things some (this doc is in early draft and may still have bugs) https://dl.dropboxusercontent.com/u/...xplainedV2.pdf The -1 is based on what is experimentally measured for the flow around a cylinder. JP |
I am replacing my Cirrus fuselage probe with a new rail mounted probe. From my research it appears ILEC wants it turned up with the head in the same horizontal plane as the horizontal stabilizer. This will be the all moving stabilator on my Cirrus. Do you guys agree with this placement?
Lane XF |
On Friday, December 5, 2014 7:42:13 AM UTC-5, wrote:
I am replacing my Cirrus fuselage probe with a new rail mounted probe. From my research it appears ILEC wants it turned up with the head in the same horizontal plane as the horizontal stabilizer. This will be the all moving stabilator on my Cirrus. Do you guys agree with this placement? Lane XF Sensing quality, assuming fin mounting is generally improved by being as high as possible above the wing root wake and well forward of the pressure field from the tail surfaces. "Well forward", from my experience, is at least 24 inches. I have found no improvement when going more than 36 inches forward and the improvement is fairly small above 24 inches. UH |
Thank you JP. I'll dig into the info today.
Forgive me for this simple-minded question. What pressure (static, dynamic, total) is provided to the variometer by the TE probe? I have read that a TE probe must create a pressure inverse but equal in maginitude to the dynamic pressure at the pitot. This confuses me. I thought the pitot 'receives' total pressure not just dynamic pressure. I do understand that a variometer is a flow meter that responds to the flow of air between a capacity and the pressure sensed by the static ports. Does the TE probe provide this static pressure (offset by changes in dynamic pressure created by the glider varying airspeeds) or is the TE probe providing dynamic pressure to its side of the variometer? I am trying to understand the TE process without being able to actually measure the pressures involved. Thank you. |
Without getting into the math (mainly because I don't remember any of
it), the TE probe delivers static pressure reduced by the suction effect caused by the air flowing around the probe. Remember that the holes in the TE probe are near the back and, according to Bernoulli (I think it was), when the velocity increases around the probe the pressure is reduced and vice versa. On 12/5/2014 9:26 AM, Jim Lewis wrote: Thank you JP. I'll dig into the info today. Forgive me for this simple-minded question. What pressure (static, dynamic, total) is provided to the variometer by the TE probe? I have read that a TE probe must create a pressure inverse but equal in maginitude to the dynamic pressure at the pitot. This confuses me. I thought the pitot 'receives' total pressure not just dynamic pressure. I do understand that a variometer is a flow meter that responds to the flow of air between a capacity and the pressure sensed by the static ports. Does the TE probe provide this static pressure (offset by changes in dynamic pressure created by the glider varying airspeeds) or is the TE probe providing dynamic pressure to its side of the variometer? I am trying to understand the TE process without being able to actually measure the pressures involved. Thank you. -- --- Dan Marotta |
Thank you Dan. That helps a lot.
On Friday, December 5, 2014 11:26:06 AM UTC-5, Jim Lewis wrote:
Thank you JP. I'll dig into the info today. Forgive me for this simple-minded question. What pressure (static, dynamic, total) is provided to the variometer by the TE probe? I have read that a TE probe must create a pressure inverse but equal in maginitude to the dynamic pressure at the pitot. This confuses me. I thought the pitot 'receives' total pressure not just dynamic pressure. I do understand that a variometer is a flow meter that responds to the flow of air between a capacity and the pressure sensed by the static ports. Does the TE probe provide this static pressure (offset by changes in dynamic pressure created by the glider varying airspeeds) or is the TE probe providing dynamic pressure to its side of the variometer? I am trying to understand the TE process without being able to actually measure the pressures involved. Thank you. The pitot does indeed have an absolute pressure equal to local static pressure plus dynamic pressure. An airspeed indicator compares this to static, so far all intents and purposes, static pressure is meaningless. A FLOW type variometer uses TE pressure(Pitot x -1) to compensate the variometer for velocity change. Static is not a factor. In transducer type varios, there is no flow. These devices use pitot compared to static, and TE compared to static to get a similar result. Some others do not use TE pressure and derive required input by inverting pitot signal electronically. For most folks it is good enough top take this stuff on "faith". It does work. UH |
Thank you again UH. I do take this on faith since I understand the purpose of the total energy compensation and I can see its effects. Unfortunately, students sometimes ask 'how'. I feel I must avoid talking nonsense when they ask. So far I have just replied that I do not know 'how' but I do know 'what'. After several such experiences my own curiosity has led me to try to understand 'how'. I guess I can't help myself!
On Friday, December 5, 2014 5:20:55 PM UTC, Jim Lewis wrote:
Thank you again UH. I do take this on faith since I understand the purpose of the total energy compensation and I can see its effects. Unfortunately, students sometimes ask 'how'. I feel I must avoid talking nonsense when they ask. So far I have just replied that I do not know 'how' but I do know 'what'. After several such experiences my own curiosity has led me to try to understand 'how'. I guess I can't help myself! For another excellent reference about pneumatic tubing and TE compensation see Part 1 of this paper by Dave Ellis (now of ClearNav and previously the designer of the Cambridge 302) http://www.clearnav.net/Technical/Va...pneumatics.pdf John Galloway |
TE probe? | [email protected] | Soaring | 12 | July 29th 14 03:54 AM |
TE probe up or down? | kirk.stant | Soaring | 25 | September 29th 10 07:48 PM |
Ka-6 TE Probe | vontresc | Soaring | 14 | August 30th 08 03:17 AM |
TE Probe on ASW-15 | [email protected] | Soaring | 4 | April 29th 07 01:43 AM |
TE-Probe for 1-26D | Heinz Gehlhaar | Soaring | 6 | January 17th 05 10:52 PM |
