What is the L/D penalty of outside mounted GoPros?
Old January 6th 15, 03:43 PM posted to rec.aviation.soaring
PBA
Default What is the L/D penalty of outside mounted GoPros?
Flubber,
Serious answer: I love flatland soaring and I'm not bored with it by any means. Video taping my own flatland flights has increased my passion and satisfaction with soaring immensely. I was just comparing my 5-hr local flatland soaring video to B4's edited, 1-hr, monster XC, mountain flight. Boring in comparison
Old January 6th 15, 04:21 PM posted to rec.aviation.soaring
Thanks for all the suggestions and ideas posted. The idea is to have possibly 4 cameras running during any given flight that I can draw footage from to tell the story of that flight. I'm just trying to continue to up the game since equipment is making it more possible to tell stories and show what we are experiencing up there in the skies better than ever before.
My biggest problem with these lipstick cams is that the field of view is still too narrow. The one that Andy mentioned is only 140 degrees. The Hero3 is 170 degrees. I am finding that wider is better for helping the audience feel they are there.
Thanks,
Bruno - B4
Old January 6th 15, 04:48 PM posted to rec.aviation.soaring
JS
Howsitgoin, Bruno!
Nice videos. (and hopefully some year I can get to Nephi for one of your camps, but work always gets in the bloody way)
For a laugh, do you think anyone asked these questions when a wing-mount camera required lead weight on the other tip?
Old January 6th 15, 07:00 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Thanks,
Bruno - B4
I've had good luck with wide angle and fisheye conversion lenses (up to 180 degree FOV). Like this:
http://www.bhphotovideo.com/c/produc... on_Lens.html
An example video with a fisheye lens converter:
https://www.youtube.com/watch?v=9aDJLDQ-5QU
The GoPro produces a fair amount of barrel distortion that may be less desirable on external shots with the glider wings, etc. in the frame - depends on what you are looking for. You can fix the distortion in post with the right software tools but that's a time-consuming pain.
There are all sorts of lenses with their own FOV and degree of distortion so it's easy to change.
3 GoPros out in the breeze will make your ASW-27 into an ASW-19 more or less. Use of aerodynamic fairings can reduce the drag by a factor of 3-5.
Can't wait to see what you come up with.
9B
Old January 7th 15, 01:19 AM posted to rec.aviation.soaring
Bruno-
Forgive the bit of thread drift....
What mount is that you have on your glareshield in your latest video? Always enjoy watching your video!
Old January 7th 15, 04:18 PM posted to rec.aviation.soaring
On Tuesday, January 6, 2015 6:19:33 PM UTC-7, wrote:
Bruno-
Thanks for the kind remarks Jeffrey. I made it myself. Piece of shaped balsa wood painted black, velcro from WalMart, 1/4" screw to fit into GoPro Camera mount threaded base, pipe teflon on screw to make camera not turn on its own.
Andy - I have had mixed results with the lenses. At this point, I am aiming for the clearest quality as possible, it would be nice to see all instruments on panel clearly.
Also, thanks Surge for the software suggestion - I will check it out!
Bruno -B4
Old January 7th 15, 05:59 AM posted to rec.aviation.soaring
Surge
Thanks,
Bruno - B4
I personally don't like the wide angle shots as one gets too much extension distortion (objects close to the camera look too large relative to objects in the distance which appear too small). On top of that there is the horrendous barrel distortion to take care of.
It however does makes the video look more impressive as it gives the impression of higher speeds as distance objects grow in size rapidly before flashing by.
For me the idea setup would be a GoPro shooting at 2.7K and processed to remove the barrel distortion, image stabilized and then cropped to 1080p to reduce the FOV.
One product which can do all of the above for the price of an aerotow is ProDad ProDRENALIN http://www.prodad.com/home/products/...2316,l-us.html
Maybe someone would like to make GoPro fairings for glider pilots.
Old January 11th 15, 09:58 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Like this?
https://drive.google.com/file/d/0Bw1...ew?usp=sharing
9B
Old January 12th 15, 04:38 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Like this?
9B
9B
Old January 12th 15, 04:48 AM posted to rec.aviation.soaring
Andy, thanks for playing around with the farings idea. How much drag do you really think this would save? I think it would be a fun project.
Bruno - B4
Externally mounted GoPros okay? Jim Lewis[_2_] Soaring 4 December 30th 14 10:52 PM
UO penalty @ Hobbs For Example John Smith Soaring 4 June 12th 05 08:34 PM
There is no penalty for failing to make the required FAA reports or investigation! Larry Dighera Piloting 9 October 12th 04 04:06 AM
TFR Penalty Magellan Piloting 9 September 5th 04 01:24 AM
~ US JOINS CHINA & IRAN AS TOP DEATH PENALTY USERS ~ Matt Wiser Military Aviation 0 April 8th 04 02:55 PM
