Weight or wing loading?
Old February 17th 15, 06:34 PM posted to rec.aviation.soaring
Default Weight or wing loading?
On Tuesday, February 17, 2015 at 12:53:58 PM UTC-5, Jim Lewis wrote:
Does wing loading have any affect on thermalling ability of a glider (pilot's ability is another topic)?
I am ignoring here the smaller turn radius, and so greater ability of a lighter wing-loaded glider to work narrow-diameter thermals. In a given thermal with a diameter that can be worked with identical airspeed and bank angle by two gliders, one with lower wing loading, does smaller wing loading have any affect on the rate at which the gliders climb in the thermal?
Given gliders each weighing 800 lbs., but one has a wing loading just 75% of the other, wouldn't they both still require a minimum of 800 lbs of thermal force to hold altitude and wouldn't they both climb at the same rate in stronger but identical (whatever that means) thermal force? I'm remembering F=ma (more usefully, a = F/m) from physics classes MANY years ago. "Wing loading", or whatever its equivalent would be, does not appear in the force formula.
Whatever the answer may be it certainly will not improve my poor thermalling. Just curious.
All other variables being equal- not likely, the glider with the lowest span loading will climb the best.
UH
Wing Loading Dan Marotta Soaring 11 April 27th 12 02:29 PM
Wing loading Andy[_1_] Soaring 2 March 11th 08 05:57 AM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Why don't all fighters have low Wing Loading? Chad Irby Military Aviation 6 September 22nd 03 10:52 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
