TE Probe install?
Old February 19th 15, 02:32 PM posted to rec.aviation.soaring
Default TE Probe install?
On Wednesday, February 18, 2015 at 4:16:57 PM UTC-5, wrote:
I'd like to install a TE probe in the fin of my ASW 19.
What angle should the prob receiver be installed at on the fin?
It looks like most TE probes are installed so the probe is parallel to the horizontal stabilizer.
Is there an optimal spot on the fin to install the TE probe?
Thanks,
Nick
ILEC has a service bulletin describing where they recommend the probe be mounted. I will paste info here for your reference.
"Fitting of the tube: On modern sailplanes, a short brass tube which serves as the receptacle for the probe is mounted on the aft fuselage or, more commonly on the vertical stabilizer. These mounts are available from the dealer.
Be sure the inner surface of the receptacle is smooth, as any roughness will damage the o-ring seal. Lightly grease the inner surface of the receptacle. (Vaseline works well.) The bore of the receptacle must be smooth and within +.02 -.00 mm tolerance.
Position of the tube: It is strongly advised not to position the tube in the vicinity of the wing, or even worse, in front of the canopy. Such positions should only be used on very low performance gliders with a narrow speed range when no other way is possible. If you must mount on the fuselage, try to mount it at least one meter behind the trailing edge of the wing.
The position high on the vertical stabilizer is best. The probe head should be in line with the top of the vertical stabilizer, or in the case of T tailed gliders, in line with the horizontal stabilizer. Positions half way up the vertical stabilizer are normally not as good because of the airflow interference with the fuselage, tailplane, fin and the wake of the wing and fuselage.
Alignment: You may closely approximate the best position by making the probe parallel with the axis of the aft fuselage cone. A more precise method is to determine the inclination of the glider in flight with the help of a spirit level, at the speed of best glide. Level the glider in this position, and adjust the tube to be level. For fuselage mounts, the base of the stem should be perpendicular with the fuselage.
Orientation: On the fin, position the tube so the measuring head is pointed upward. For the fuselage mount, the holes should be pointed aft."
Old February 19th 15, 10:44 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
The T/E line needs to be anchored inside the tail boom, away from the elevator push-rod and bell-crank. Slick way to accomplish this is to make up 2 anchor rings from 1" plastic pipe cut to 1" lengths. With the T/E line in place inside the tail boom, goop up the outside of the rings with epoxy and flox then slide them down the T/E tube placing (one, 1/3 way and the other 2/3 way down the tail boom). When anchors are located at the proper spot inside the tail boom, allow the T/E line to lower down so that the rings come to rest on the bottom of the boom. The epoxy and flox mix will slowly ooze down and stick to the inside of the fuselage. This is from Will Schuemann as a way to add aft statics for the 301 Libelle.
JJ
TE probe? [email protected] Soaring 12 July 29th 14 03:54 AM
How to install tubing on the te probe 1/2 way to the rudder? [email protected] Soaring 14 April 5th 09 08:20 PM
Ka-6 TE Probe vontresc Soaring 14 August 30th 08 03:17 AM
TE Probe on ASW-15 [email protected] Soaring 4 April 29th 07 01:43 AM
TE-Probe for 1-26D Heinz Gehlhaar Soaring 6 January 17th 05 10:52 PM
