Hi,
I have cables for connecting an LX EOS to an Oudie. You can see details he http://www.cumulus-soaring.com/lx.htm#LX-EOS NOTE: Make sure you use the most recent EOS manual. The original version had the wiring connections backwards for transmit and receive on several ports. I have EOS units in stock. However, I haven't tested connection to an Oudie yet, so I can't answer all of your questions below. Best Regards, Paul Remde Cumulus Soaring, Inc. "Ventus2NZ" wrote in message ... Oudie 2 to LX Navigation EOS. Has anyone connected this combo together? 1- What cables did you use 2- What hardware did you select in the Oudie menu 3- Do you have a wiring diagram of the pinouts 4- Does connectme work for file download 5- What hardware did you select in connect me menu 6- What baudrate did you select With thanks. |
Oudie2 to LX Navigation EOS | Ventus2NZ | Soaring | 0 | February 23rd 15 08:06 AM |
Problem updating Oudie2 to 6.0 | kirk.stant | Soaring | 5 | November 18th 14 03:10 AM |
Oudie2 connection to LXnav V7 | John Docherty[_2_] | Soaring | 4 | October 16th 14 02:27 PM |
Oudie2 Units in Stock | Paul Remde | Soaring | 0 | August 30th 12 03:14 PM |
Oudie2's available again in the USA - Upgrades also available | Paul Remde | Soaring | 0 | August 20th 12 09:32 PM |
