Proairsport. New ultra light glider/airplane
Old March 19th 15, 04:46 PM posted to rec.aviation.soaring
Roger Hurley[_2_]
Default Proairsport. New ultra light glider/airplane
At 14:38 19 March 2015, Martin Gregorie wrote:
On Thu, 19 Mar 2015 07:22:27 -0700, Bruce Hoult wrote:
Why, other than the weight of the electric motor and battery?
Wheelspin around the liftoff speed would kill acceleration and may
lengthen the takeoff run, especially on wet grass.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
The aircraft sits on its mainwheels and nosewheel - the wing has a negative
angle of attack, no lift produced. Throughout the acceleration this
condition is maintained, until rotation speed is reached.
Independence, Operational Convenience, Simplicity, Lower Cost.
Questions to me via website.
R
Old March 19th 15, 05:47 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Actually, Roger, I really like the idea of drive wheels for acceleration. Maybe because I had the same thought for being able to self launch a very light sailplane from a ridge site 25+ years ago. At the time, my thought was for a simple 12 volt battery (like most sailplanes have) to drive a model airplane electric starter motor, belt driving the wheel on the glider. Never was too keen on the idea of trying to launch in light wind, running while carrying and controling a flying machine.
Hope you weren't offended by my "burnout" comment. Looks like you are working to resolve the issues that we all face. Now, if we can get the production volume up on the jets to get the cost down...
Steve Leonard
Old March 19th 15, 06:03 PM posted to rec.aviation.soaring
kirk.stant
Interesting concept - wondering how many takeoffs are planned per battery charge?
And unless the tires (tyres?) are a bit wider, it might have trouble at some of the rougher grass fields I've flown from.
But a more important question: What does GloW mean? C'mon, guys, if you use a cute acronym (and you Brits are worse than us 'Muricans - QinetiQ, really?) at least explain how it was derived!
Kirk
Old March 20th 15, 09:40 AM posted to rec.aviation.soaring
The electric powered wheel is such a bad idea that Airbus has been testing it on airliners. Using it for taxi and acceleration during take off reduces fuel consumption considerably and shortens takeoff distance. Newer electric motors can produce tremendous amounts of torque and are much lighter. Just what you need for initial acceleration.
Current self launchers are many times equipped with finicky engines and complicated mechanics to expose the prop. When you need the lowest sink rate to prevent a land out, deploying the motor decreases the glider's performance to it's lowest.
If our sport is to survive, we need innovation. A low maintenance, affordable self launch could go a long way toward that goal.
Charlie
mass of Ultra light thingies Glenn[_2_] Aviation Photos 0 September 9th 07 01:03 PM
Another ultra light thingy Glenn[_2_] Aviation Photos 0 September 9th 07 01:01 PM
Some Ultra Light thingy Glenn[_2_] Aviation Photos 0 September 9th 07 12:55 PM
Ultra light Glider regulations Denis G Soaring 5 May 24th 04 06:19 PM
Ultra Light Towing Randal Cullen Soaring 9 February 9th 04 05:41 AM
