All the PTT switch does is ground a logic gate, so unshielded 22-24 Tefzel is more than adequate. I personally wouldn't use a connector, just run from the switches to the connectors on the back of the Becker and the V7 (less to go wrong).
-John, Q3 On Tuesday, April 21, 2015 at 2:55:25 PM UTC-4, wrote: I have a Becker 4201 and I'm wiring up a PTT and vario switch in the stick grip. Many people have posted that 22-24 tefzel is the stuff to use. Should the wire be shielded? Is there a "best" type of quick disconnect connector to use for this small guage wire. I was going to use a JST connector, although I have no idea how much current is running through the PTT or the V7 climb circuit... Nick |
Wiring in a KI 214 | apachearmtguy | General Aviation | 1 | November 10th 09 02:15 AM |
wiring | Jerry Wass | Home Built | 7 | January 3rd 09 09:03 PM |
Wiring | Jerry Wass | Home Built | 1 | January 2nd 09 03:44 AM |
Wiring KX 175 TSO | Tore B. | General Aviation | 0 | May 6th 04 10:02 PM |
Wiring KDR-510 | Chad Lemmen | Owning | 3 | September 16th 03 02:03 PM |
