Borgelt B50 and PowerFLARM Question
Old May 11th 15, 05:17 PM posted to rec.aviation.soaring
Paul Remde
Default Borgelt B50 and PowerFLARM Question
Hi,
A customer has asked me to help him connect his PowerFLARM Core to his
Borgelt B50 and Naviter Oudie.
He had ordered a K6 Mux - which would definitely work, but I wonder if a
simpler and less expensive cable solution would also work well. I have the
required Goddard PBvB50 cable in stock.
The B50 manual states that it communicates at 4800 baud by default and can
be configured using a jumper to communicate at 9600 baud. The PowerFLARM
and Oudie can also be configured to communicate at 9600 baud.
The big question and the reason for this post is that I'm concerned as to
whether all the GPS and FLARM and B50 vario data can get through every
update at 9600 baud. Most FLARM systems use 19200 baud or higher to make
sure all the data gets through. Does anyone know whether or not this
approach would work?
The goal is to minimize the customer's cost while providing a reliable
system.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old May 12th 15, 07:47 AM posted to rec.aviation.soaring
Roger S
On Monday, 11 May 2015 17:18:12 UTC+1, Paul Remde wrote:
Hi,
system.
Best Regards,
Paul Remde
My experience says it won't work with the FLARM feeding through B50 - there isn't enough time to get the data through at 9600. I managed to get a B50 working with a plain GPS by configuring the GPS to output the minimum number of NMEA sentences as the default GPS setting sent too much data and it got garbled. With FLARM data as well there would just be too much.
Roger
Old May 12th 15, 08:26 AM posted to rec.aviation.soaring
2015. május 11., hétfÅ‘ 18:18:12 UTC+2 idÅ‘pontban Paul Remde a következÅ‘t Ã*rta:
Hi,
system.
Best Regards,
Paul Remde
Hello, maybe you should try to disable some NMEA sentences, using MUX. Why do you need both GPS and FLARM for GPS data, FLARM is enough. I am doing the same with B800_GPS-FLARM-Vertica-MUX, just using FLARM GPS data for Vertica.
Old May 12th 15, 04:05 PM posted to rec.aviation.soaring
Paul Remde
Hi Roger,
Thank you for your feedback. I appreciate it.
I also received a reply from Mike Borgelt stating simply and correctly that
FLARM states that 19200 baud is required. Therefore, I have put together a
K6 Mux system for the customer. It receives the B50 data at 4800 baud and
the FLARM data at 19200 baud and sends everything to the Oudie at 19200
baud. The customer will receive a "plug-n-play" system. The K6 Mux is a
great product. I was just trying to look at all possibilities in an effort
to minimize cost for the customer.
Best Regards,
Paul Remde
"Roger S" wrote in message
Hi,
system.
Best Regards,
Paul Remde
Roger
Old May 13th 15, 08:15 PM posted to rec.aviation.soaring
Ian[_2_]
to whether all the GPS and FLARM and B50 vario data can get through
every update at 9600 baud. Most FLARM systems use 19200 baud or higher
to make sure all the data gets through. Does anyone know whether or not
this approach would work?
I have a B500 + Clasic Flarm talking to a Dell Streak running XCSoar via
a IOIO card. The B500 runs at 4800 and the Flarm at 19200. If you set
Flarm baud rate any slower than 19200, the sending of traffic alert
sentences get disabled by Flarm. Which probably defeats the object of
the exercise.
Old May 13th 15, 08:48 PM posted to rec.aviation.soaring
Dave Nadler
On Wednesday, May 13, 2015 at 3:16:01 PM UTC-4, Ian wrote:
...If you set
the exercise.
Per the manual: With FLARM baud rate 19200:
- traffic alerts are suppressed
- collision warnings are NOT suppressed
Question about PowerFlarm IGC recording rate SoaringXCellence Soaring 5 June 6th 13 11:51 PM
Stupid PowerFLARM Question Peter von Tresckow Soaring 9 March 1st 12 11:50 AM
PowerFLARM Mode S question kirk.stant Soaring 54 October 26th 10 02:51 PM
Borgelt B40 question tuno Soaring 4 June 17th 04 02:33 PM
