Gliders Transponder exemption and Project EVA
Old June 24th 15, 04:10 PM posted to rec.aviation.soaring
Bill T
Default Gliders Transponder exemption and Project EVA
Marty, I would like to believe that individuals are doing due diligence and research before speaking (on the forum) or posting to the FAA comment page.. I know I am researching the TABS tech requirements and what that means to gliders or other battery only, or no battery aircraft. The FAA needs to allow battery and wiring installations with field approvals from knowledgeable IAs and DARs for standard certificated aircraft. Plus the monetary impact for the equipment. This cannot be applied to gliders only, although gliders may have the most impact above 10,000 MSL. Not many J-3 Cubs, balloons or hang gliders above 10K.
Plus there are a lot of people on safari, or contest flying right now. I do agree that this needs to be kept on the forefront so pilots do respond smartly to the FAA comment board.
BillT
ANPRM - removal of transponder exception for gliders [email protected] Soaring 29 June 17th 15 11:00 PM
New Transponder Code (1202) for Gliders (Effective Feb 9, 2012) 5Z Soaring 2 May 25th 11 11:02 PM
Non-discrete transponder codes for gliders zulu Soaring 2 January 3rd 10 04:10 AM
(USA) NTSB issues recommendations to the FAA and the SSA regarding transponder use in gliders BT Soaring 78 July 25th 08 06:26 PM
(USA) NTSB issues recommendations to the FAA and the SSAregarding transponder use in gliders Andy[_1_] Soaring 4 May 22nd 08 05:16 PM
