Removed very old gelcoat that easily before, but no power tools needed. Just a paint scraper and next thing you know it's 4AM and you're still laughing at the gelcoat easily falling off.
It's amazing that particular glider could still fly with the unlogged amateur combat repair found under the gelcoat on one wing. Unfortunately Uncle Fuzzy isn't around to comment on his technique used in the video. I did get to fly that glider prior to refinish and with him after the refinish. Before refinish you could easily cut yourself on the cracks.. Pieces of gelcoat would come off if poked. Nice job. Jim |
Yes, I miss Jim and his inventive ways. I have always thought we should be able to build a gelplane for gliders. Very fine adjustments to allow leaving a thin layer of gel coat but remove the bulk of the material before using the sanders.
and deprive Andy of his daily allowance of Gel Coat Dust???
Tim, I looked at a gelplane in action at a boat repair facility "down the shore" a couple of years ago. On the face of it, it's an attractive option. However, I think the challenge is that in my experience, the gelcoat thickness on a glider wing varies considerably. I'm sure you've noticed places where you can almost see the glass or carbon cloth through the gelcoat and others where it's completely opaque. I don't know how you'd avoid lopping off some of the outer layer of skins. I have heard that one or two shops in Europe have some experience with them, so maybe there's something to it?
P3 |
Erik,
I could see a plane that integrates an ultra sound unit to ensure saftey and avoid cutting into the fiber layer. As expensive and miserable as grinding the gel coat off an advanced system would be valuable to the soaring community. After watching the gelplane work on boats we should be able to makes something that is better for gliders. |
On Thursday, July 9, 2015 at 10:39:25 PM UTC-4, Papa3 wrote:
Tim, I looked at a gelplane in action at a boat repair facility "down the shore" a couple of years ago. On the face of it, it's an attractive option. However, I think the challenge is that in my experience, the gelcoat thickness on a glider wing varies considerably. I'm sure you've noticed places where you can almost see the glass or carbon cloth through the gelcoat and others where it's completely opaque. I don't know how you'd avoid lopping off some of the outer layer of skins. I have heard that one or two shops in Europe have some experience with them, so maybe there's something to it? P3 right you are! |
On Thursday, July 9, 2015 at 4:32:26 PM UTC-4, Tim Taylor wrote:
Yes, I miss Jim and his inventive ways. I have always thought we should be able to build a gelplane for gliders. Very fine adjustments to allow leaving a thin layer of gel coat but remove the bulk of the material before using the sanders. it would be easier that way! the problem with a "plane" is that the gelcoat/paint thickness is not uniform for several reasons. if you try and take a set thickness off, in some places you'll go through and get into the structure. |
Gel coat removal - water sanding vs. straight line sanding | LS3 Pilot | Soaring | 45 | February 15th 10 03:32 PM |
Gel coat inspection | Matt Keast[_2_] | Soaring | 12 | October 26th 07 09:14 PM |
Gel Coat Question | Gary Emerson | Soaring | 2 | September 12th 07 11:56 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 12 | December 24th 04 01:12 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 2 | December 12th 04 08:15 PM |
