Gel coat removal - is this okay?!?
Old July 10th 15, 05:58 AM posted to rec.aviation.soaring
Bill T
Default Gel coat removal - is this okay?!?
JW was a master at anything he touched. Fiberglass, welding, plastics, motors, it did not matter.
That gelcoat was flaking off the wing, it just needed a little encouragement. The pin holes were filled before the poly paint and sanding.
The finish is factory perfect, actually better than factory. There are YouTube videos of the glider after the work was completed.
It is a joy to fly.
You will also find videos of Jim flying his beloved Speed Astir, "UF", hence the Uncle Fuzzy monicker.
Jim is surely missed.
BillT
Gel coat removal - water sanding vs. straight line sanding LS3 Pilot Soaring 45 February 15th 10 03:32 PM
Gel coat inspection Matt Keast[_2_] Soaring 12 October 26th 07 09:14 PM
Gel Coat Question Gary Emerson Soaring 2 September 12th 07 11:56 AM
Gel Coat for Dummies Ray Lovinggood Soaring 12 December 24th 04 01:12 AM
Gel Coat for Dummies Ray Lovinggood Soaring 2 December 12th 04 08:15 PM
