Weight & Bal Calc ASK-21
Old October 25th 15, 02:34 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default Weight & Bal Calc ASK-21
If you do your own calculations, please be aware of a very common error. Some manuals use a formula for C/G which uses the distance between the main wheel and the tail wheel. Others use a formula that use the distant to the tail wheel from the datum. Either one will work, but if you use the wrong distance to the tail wheel it creates a 3-5% error in the final C/G. It usually goes unnoticed as it is small, but I have seen this even from official W&B sheets.
Matt H
Old October 26th 15, 11:47 AM posted to rec.aviation.soaring
Per Carlin
Matt H
And do NOT trust an old and unkown W&B. I have seen to many of them that has been wrong, both in mass and distance and therefore in CG, even the original factory W&B can not be trusted as it sometimes is pre-made prior to finishing of the glider.
Do it your self properly once. Any change in instruments, ballast, trim weights, etc can later on be calculated.
/Per
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 10:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 06:01 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
Route calc. Montblack Piloting 0 July 11th 03 01:52 AM
