Weight & Bal Calc ASK-21
Old October 29th 15, 03:44 PM posted to rec.aviation.soaring
Skytime
Default Weight & Bal Calc ASK-21
On Saturday, October 24, 2015 at 10:29:48 AM UTC-5, Matt Herron Jr. wrote:
On Saturday, October 24, 2015 at 5:45:49 AM UTC-7, Skytime wrote:
Anyone have a simple wt. & bal calc method for ASK-21? The manual is all in German and makes no sense. Power-plane manuals are simple to use with a graph.
May I shamelessly recommend SeeG, a program specifically designed for C/G calculation on gliders, one seat or two. http://www.glideplan.com/styled-2/page12/index.html Simple, fast, and flexible.
Matt Herron
Thanks. I stay with the paper math.
I would rather spend the $80 bucks on paying for a tow.
Old October 29th 15, 05:30 PM posted to rec.aviation.soaring
JS
Since this thread appeared, I contacted Matt Herron about phone apps. Getting the feeling it's not going to happen.
However, I downloaded the Appventive Weight + Balance app for Android and it works well. Will contact the developer with a couple of questions, primarily wanting to increase resolution an order of magnitude.
It's $10, and can be with you when you're adding a passenger, water ballast, etc. I move the fuel tanks, rename them and use weight as the input for water ballast.
Will also try Matt's SeeG program. The Jonker Sailplanes spreadsheet for the JS1 is the best I've used so far, wish all manufacturers had something like that to download. But spreadsheets aren't great on a smart phone.
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 10:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 06:01 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
Route calc. Montblack Piloting 0 July 11th 03 01:52 AM
