We got a heads up based on the European AD equivalent release, Knowing the FAA would follow. Our Annual inspection was due so we completed and logged the SB inspections. All was good.
Now the AD says "unless already completed" comply within 30days. We are done until our next annual. Thanks for the heads up JS. We do not have the inspection ports in the lower wing, we were able to inspect and take pictures with a long lighted bore scope through the wing root. Interesting comment about installing those inspection ports, are clear plastic covers available? BillT |
On Friday, October 30, 2015 at 8:51:41 PM UTC-7, Bill T wrote:
Interesting comment about installing those inspection ports, are clear plastic covers available? BillT Polycarbonate sheet (aka Lexan), easy to machine/cut with woodworking tools, hell for stout. http://www.amazon.com/Polycarbonate-.../dp/B00CPRCQ9E |
Grob gliders, new TM about control system pulleys | Robert M | Soaring | 5 | February 14th 14 04:47 PM |
Grob 102 Spar Spogot AD note | [email protected] | Soaring | 0 | January 10th 11 08:45 PM |
Grob 103 AD note for bolt, USA | [email protected] | Soaring | 2 | March 2nd 09 05:47 PM |
Grob G-103 AD note, USA | [email protected] | Soaring | 1 | February 27th 09 11:05 AM |
Grob AD note. Stemme AD note. | pbc76049 | Soaring | 0 | August 21st 06 03:23 PM |
