Weight & Bal Calc ASK-21
Old November 1st 15, 02:35 PM posted to rec.aviation.soaring
GeneReinecke
Default Weight & Bal Calc ASK-21
On Sunday, November 1, 2015 at 6:22:23 AM UTC-7, Casey Cox wrote:
On Sunday, November 1, 2015 at 7:21:27 AM UTC-5, Casey Cox wrote:
I found these pages from the manual which are much clearer and, easy to print graph.
http://www.alexander-schleicher.de/w...TM35_US_HB.pdf
Question for anyone:
How does one calculate or develop what I've seen called (Wedge), (Level Line), (Incidence Board)?
To ensure the fuselage is level, and in this case for the ASK-21 is 1000:52. And also in this case there is no reference of exact placement. Wouldn't it change the level if the board is more forward or more to the rear?
Here is wording in another manual;
The horizontal reference line is the centre line of the fuselage tail cone or a 1000 : 45 wedge template levelled out on the top side of the fuselage aft portion
It is always easier to use a professional to weigh your glider. However, per my owner's manual, I did the math (1000:45/2) on a 50" piece of 2 x 4, cut the smaller piece (approx. 2.25 in) and duct taped it at a right angle. I then took the glider and my assy to our local A&P. He had a fancy digital incidence scale in addition to good aircraft weight scales. Although we went with his methodology, I was happy to see me homemade incidence taper was dead on. Design with a supercomputer, measure with a micrometer, cut with a sawzall...
Cheers
Gene
Old November 1st 15, 03:14 PM posted to rec.aviation.soaring
Dan Marotta
Or, as we said in the Air Farce: Measure with a micrometer, mark with a
grease pencil, cut with an axe. I don't think we had supercomputers
back then...
Cheers
Gene
Dan, 5J
Old November 1st 15, 04:00 PM posted to rec.aviation.soaring
Casey Cox
I just found one specific glider manual stating 1000:40 with 300 mm in front of vertical stabilizer. Either it makes some difference in this specific glider or the manufacture is more precise.
Casey
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 10:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 06:01 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
Route calc. Montblack Piloting 0 July 11th 03 01:52 AM
