LX 9000 or CNII?
Old November 14th 15, 06:06 AM posted to rec.aviation.soaring
JS
Default LX 9000 or CNII?
"Different strokes for different folks" (Sly & the Family Stone - Everyday People)
Another biased opinion:
Both are good. Wish I had more time to evaluate the LX9000, which seemed intuitive. Only one flight, and that was nearly four years ago. Hardly valid for software-based instrumentation.
Currently using CN2 and Air-Glide S.
Did have problems with shipping US to Slovenia and back for another computer, but perhaps that was to the Judean People's Front, not the People's Front of Judea. Shipping US to anywhere in Slovenia involves the same logistics.. In my case FedEx would cost much of what the instrument was worth, USPS tracking failed at the Slovenian border.
Perhaps a consideration: The LX uses binary airspace files - so building your own, ie TFR file, is more complicated. Using a text editor you can build an open air file in a few minutes or alternately download from Lynn Alley.
Whichever device you personally choose, I recommend using a stick-mounted controller and mounting the display in the panel. Take into account the new height of the stick with remote when you lay the panel out. Shortening the stick ~30mm might help.
Old November 14th 15, 03:48 PM posted to rec.aviation.soaring
Dave Springford
While the cub file used for the LX9000 airspace is a binary file, as long as you have a copy of SeeYou, you can create a cub file easily using the Mobile Wizard.
As JS says you sometimes want to build your own Open Air file using a text editor, you can still do that for the 9000. Build the Open Air file, load it into SeeYou and then export it to cub format using the Mobile Wizard - done!
Old November 14th 15, 04:07 PM posted to rec.aviation.soaring
Dan Marotta
....Assuming you have SeeYou, which I don't. Or does that license come
with the LX products?
Dan, 5J
Old November 14th 15, 08:14 PM posted to rec.aviation.soaring
Tom (2N0)
See you comes in handy. I used it to export maps that did not come with the LXSim download.
Old November 14th 15, 09:40 PM posted to rec.aviation.soaring
Dave Springford
Well, I did say, "assuming you have SeeYou".
Why would any cross-country glider pilot not have SeeYou?
Old November 14th 15, 09:43 PM posted to rec.aviation.soaring
Dave Springford
Well, I did say "as long as you have" SeeYou.
Old November 14th 15, 10:41 PM posted to rec.aviation.soaring
Because we use other programs that work for us?
Old November 15th 15, 02:19 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
The phrase "Why would a cross-country glider pilot not have __________?" is a question that already contains its own answer.
It is the words "glider pilot".
9B
Old November 15th 15, 03:49 PM posted to rec.aviation.soaring
Dan Marotta
Been flying cross country in gliders for 25+ years and never had
SeeYou. Only had a computer for the past 5 or so years and yes, they're
nice, but not necessary in my opinion. I can analyze my flights on
Skylines at home. I'm not knocking any product, just the assumption
that you must have this or that. Each has its followers and each works
for those who use them. And BTW, ATP or not, I still consider myself a
"glider pilot". ;-)
9B
Dan, 5J
Old November 15th 15, 04:09 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Don't need it - I've got GPLIGC.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
CNII 3.0.1.27 & CNv 3.0.3343 betas available Tango Eight Soaring 1 May 27th 15 03:12 PM
CNv 3.0 (beta) and CNII 3.0.1.25 updates available Tango Eight Soaring 8 April 7th 15 02:19 AM
ClearNav vs. LX 9000 Mitch Polinsky Soaring 9 September 4th 11 04:46 PM
LXNAV Nano and LX 9000 Overview Videos Available Paul Remde Soaring 3 February 28th 11 01:58 PM
28 years, 9000 hours Jay Honeck[_2_] Piloting 60 March 10th 08 01:19 PM
