CNv 3.0 (beta) and CNII 3.0.1.25 updates available
Old April 4th 15, 07:36 PM posted to rec.aviation.soaring
Tango Eight
Default CNv 3.0 (beta) and CNII 3.0.1.25 updates available
CNv 3.0 is a significant performance and feature upgrade for CNv variometer.
CNII 3.0.1.25 is a bug fix release for CNII flight computer. Both are important and recommended for all users.
Get them here http://www.clearnav.net/main/cn-downloads.html
Please read all release notes and instructions --- thanks!
Please join our forum for discussion of all things ClearNav:
http://clearnav.net/simplemachinesforum/
Evan Ludeman for CNi
www.clearnav.net
Old April 5th 15, 04:49 AM posted to rec.aviation.soaring
So, from reading the instructions, I need to get an updated license file
via my dealer before I try this? I already have a V1C-XC.lic file
on my thumb drive.
Matt
Old April 5th 15, 02:28 PM posted to rec.aviation.soaring
Tango Eight
on my thumb drive.
Matt
Your existing XC license is valid with 3.0, but (iirc) you will need the license available on your USB drive to enable XC feature set after the update.
-Evan
Old April 5th 15, 07:21 PM posted to rec.aviation.soaring
Dan Marotta
So, where do I find this license file? It's not on my thumb drive and,
if it lives on the vario, the update will delete it. Can I get it off
the CNv or do I have to wait until Monday and ask Gary to send me a copy?
I have the update and the current versions in sub-folders on my thumb
drive and I moved copies of the appropriate update files to the root.
Guess I'll delete the copies from the root and fly with the old firmware
today. Bummer...
on my thumb drive.
Matt
-Evan
Dan Marotta
Old April 6th 15, 02:36 PM posted to rec.aviation.soaring
Tango Eight
On Sunday, April 5, 2015 at 1:21:38 PM UTC-4, Dan Marotta wrote:
So, where do I find this license file?* It's not on my thumb drive
and, if it lives on the vario, the update will delete it.* Can I get
it off the CNv or do I have to wait until Monday and ask Gary to
send me a copy?
thumb drive and I moved copies of the appropriate update files to
the root.* Guess I'll delete the copies from the root and fly with
the old firmware today.* Bummer...
on my thumb drive.
Matt
-Evan
Dan Marotta
My mistake!!!!!!!
You need a license on the USB drive ONLY if it is a 1st time installation of CNvXC. If you already have the XC feature set enabled, you do not need a license when you upgrade.
[I needed the license on my own personal CNv, but this was because I was testing software using a different license. When I booted up in the public beta it came up CNv Club, I installed the correct license and was good to go.. What I'm saying is that I had a reason, but not an excuse :-)].
Best,
Old April 6th 15, 03:39 PM posted to rec.aviation.soaring
s6
Le dimanche 5 avril 2015 13:21:38 UTC-4, Dan Marotta a écrit*:
send me a copy?
on my thumb drive.
Matt
-Evan
Dan Marotta
Hi
I inserted the usb key in the vario, it deleted vs 2...
Vario display show vs 0.00...
I turn the vario off and on again
about 4-5 minutes later I had vs 3...
S6
Old April 6th 15, 05:36 PM posted to rec.aviation.soaring
Tango Eight
send me a copy?
on my thumb drive.
Matt
-Evan
Dan Marotta
Hi
S6
So everything works now?
Our bootloader / updater is pretty robust and I have yet to hear of anyone "bricking" a CNv. The updater *can* hang in the update process (this is rare). I think we've had one instance where an update with two connected diplays failed to finish and both displays were blank. In this case, the best way to resolve the problem is to connect only one display, re-run the update. When the update finishes, connect the second display and run the update again.
PS: I think the rest of the r.a.s community would prefer we do customer support on our own board. http://clearnav.net/simplemachinesforum/
Best,
Old April 7th 15, 02:46 AM posted to rec.aviation.soaring
Dan Marotta
Thanks for the info, Evan. I flew yesterday with v2 and saw your
message this morning. So I went to the hangar and started the upgrade.
After what appeared to be a hangup (it beeped for 30 minutes), I called
Gary and he told me to turn the unit off and then back on. Then it
updated the display and all was well.
I noticed that I can now change MC value and ballast from my Dell Streak
5 without killing the communications between the units! I'm very happy
with that. I'll have to try declaring a task from the Streak. Now I
can't wait to fly again with the new firmware.
Dan
and, if it lives on the vario, the update will delete it. Can I get
send me a copy?
the root. Guess I'll delete the copies from the root and fly with
the old firmware today. Bummer...
on my thumb drive.
Matt
-Evan
Dan Marotta
Hi
S6
Best,
Dan Marotta
Old April 7th 15, 03:19 AM posted to rec.aviation.soaring
Tango Eight
On Monday, April 6, 2015 at 8:46:37 PM UTC-4, Dan Marotta wrote:
Thanks for the info, Evan.* I flew yesterday with v2 and saw your
message this morning.* So I went to the hangar and started the
upgrade.* After what appeared to be a hangup (it beeped for 30
minutes), I called Gary and he told me to turn the unit off and then
back on.* Then it updated the display and all was well.
Streak 5 without killing the communications between the units!* I'm
very happy with that.* I'll have to try declaring a task from the
Streak.* Now I can't wait to fly again with the new firmware.
Dan
send me a copy?
on my thumb drive.
Matt
-Evan
Dan Marotta
Hi
S6
Best,
Dan Marotta
I don't believe task declaration is enabled as yet, but no harm in trying. As for the serial com problem with changing MC... that never really made any sense to me. CNI and CNII both do this with CNvXC and have since V2.0, with no problems, using the same protocol that XCS should be using (302's !g sentence).
Have fun with v3.0.
-Evan
FLARM 2.79 beta Andy[_1_] Soaring 0 April 29th 13 04:57 PM
XCSoar 6.6 beta Max Kellermann[_2_] Soaring 2 April 18th 13 03:49 PM
PowerFLARM 2.60 beta available [email protected] Soaring 7 November 2nd 12 01:11 AM
Gov Cup V2 Beta Deployed Ken Kochanski (KK) Soaring 0 July 21st 10 03:29 AM
Beta Prop Rob Fonhof Home Built 18 August 12th 05 04:24 AM
