Instrument Panel Color
Old November 24th 15, 02:38 PM posted to rec.aviation.soaring
Default Instrument Panel Color
On Monday, November 23, 2015 at 3:46:12 PM UTC-8, kirk.stant wrote:
On Monday, November 23, 2015 at 5:43:35 PM UTC-6, kirk.stant wrote:
On Monday, November 23, 2015 at 4:55:43 PM UTC-6, Waveguru wrote:
I hate it when someone paints the panel white. Don't do it. It is dangerous. There is a reason panels and instruments are black and also the noses of fighters.
Boggs
Ok, I'll bite.
Most panels in US military jets are gray, not black. Most current fighter noses (I assume you mean radomes) are also gray. Many early radomes had black rubber/plastic coatings that couldn't be painted - newer ones come in matching colors.
Oddly, panels in the latest F-15K (for Korea) and F-15SG (Singapore) are black - and trust me, it's ugly.
Russian jets tend to have an odd turquoise color panels. And Boeing airliners are an odd brown.
My panel is gray (primer color) and works just fine.
Kirk
66
And having read your post a little closer, I assume you are talking about the anti-glare panels on unpainted or white planes. Good point. The key is that the paint be flat - a glossy black can be just as reflective as glossy white!
Kirk
66
Ok I'll bite . Not sure if Boggs was making the distinction between black and grey... Anyway, wouldn't a "flat white" panel be much worse than a flat grey or flat black? I can't think of a single airplane that has a white panel of any kind. I can't even wear a light colored shirt in my non-tinted canopy glider, the glare drives me absolutely nuts. I now wear black, grey or dark blue or similar.
ASW 19 Instrument Panel CAD Drawing Jonathan Phillips Soaring 11 July 18th 18 10:56 PM
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 06:50 PM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
