Nimbus 2 load factor limits?
Old December 15th 15, 11:21 AM posted to rec.aviation.soaring
Surge
Default Nimbus 2 load factor limits?
On Tuesday, 15 December 2015 10:30:11 UTC+2, Bengt Aronsson wrote:
Well, according to the tcds linked from german CAA website (
https://www2.lba.de/data/bb/Segelflug/sp_0286_01.pdf ) its certified to
german LFS requirements without deviations. The min required load factors
then is +5.3 / -2.65g at max maneuvering speed, lineary decreasing to +4.0
/ -1.5g at Vne.
Airbrakes out requirements are +3.5 / -0g.
Thank you very much.
That railway line, main spar looks like it could take a lot more abuse than the certified limits.
Old December 15th 15, 12:09 PM posted to rec.aviation.soaring
Bruce Hoult
/ -1.5g at Vne.
I'm sure Ray Lynskey's N2 got an awful lot of high speed (and often high altitude) abuse on mountain ridges and in rotor. It survived it.
Old December 15th 15, 01:46 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
The figures quoted are the JAR22 Certification requirements of that era.
It was necessary to demonstrate that, at least in theory, it could take 50%
in excess of that, and in practice most types even exceeded that. However
that was when they were new.
to
factors
+4.0
/ -1.5g at Vne.
Old December 15th 15, 02:29 PM posted to rec.aviation.soaring
WAVEGURU
Does the aging of fiberglass weaken it? Learn something new every day here on RAS.
Boggs
Old December 15th 15, 07:16 PM posted to rec.aviation.soaring
Boggs
Looking at the chemistry, polymerization should continue as the glider ages. With more cross-links, the structure should be getting stronger with age (unlike you and I, Gary).
Torque and P-factor Marten Kemp Piloting 3 October 28th 13 04:13 AM
How Much Load for a Load Test? Brian Whatcott Home Built 13 July 6th 09 06:07 PM
Pucker Factor SOS[_3_] Piloting 0 May 31st 08 11:21 PM
DC-3/C-47 Limit Load Factor Dale General Aviation 6 July 2nd 06 04:28 AM
gpa a factor after graduation? sibersmith Military Aviation 28 November 26th 03 05:06 PM
