DG quality?
Old January 6th 16, 05:56 AM posted to rec.aviation.soaring
bumper[_4_]
Default DG quality?
On Tuesday, January 5, 2016 at 1:34:21 PM UTC-8, wrote:
I know this is somewhat subjective. Factory support agreements, etc. aside, has anyone noticed any difference in the quality of newer DG production models compared to SH and Schleicher? Thanks
Are you asking if DG's quality has gotten better or worse?
I don't know about newer or now. so this may be of no help at all and I've not heard of significant swings in quality either way. When I was comparing the DG800 to the ASH26E back in 2002, and after talking to a highly regarded composite shop who showed me some wing cutaways (things you wouldn't get to see about hidden construction quality pre-crash - unless you are handy with a chain saw), a busy local sailplane mechanic, as well as bouncing between the two at an SSA convention for a couple of hours, I chose the 26E. The veracity of the decision has been affirmed many times since.
bumper
MKIV "high tech" yaw string and Quiet Vent
Old January 6th 16, 07:46 AM posted to rec.aviation.soaring
Default DG quality?
Hey Bumper.
When are you releasing the ultra low drag version of your yaw string?
Old January 7th 16, 12:21 AM posted to rec.aviation.soaring
bumper[_4_]
Default DG quality?
On Tuesday, January 5, 2016 at 11:46:56 PM UTC-8, wrote:
Hey Bumper.
This ULD MKV project has been a closely guarded secret, so I'm curious how you found out about this. Very frustrating to have this leaked prior to our planned April 1st release date. We don't want the superlative MKV negatively impacting sales of the excellent MKIV's in stock at our dealers.
But that you've let out, here's a few details. Unlike the MKIV base that is about .038" thick to keep the yarn off the canopy, the MKV is only .005" thick. The "old" MKIV is installed on the outer surface of the canopy and is thus subject to all the vagaries of relative wind flow, turbulence, stalls, spins, falling out of the sky should you run out of wind, and of course the dreaded tail-spin.
The MKV is completely different and of epochal significance. Yes, people will refer to sailplanes as "pre and post MKV" it is that monumental a change in yaw string technology. The MKV installs inside the canopy so there's no additional drag whatsoever!
So, how did we do it? While some of the details of the new MKV are closely held trade secrets (hopefully more so than our leaked release date), I can share with you that the MKV will be available in three distinct models and several color options. The models are "Left", "Right", and we expect to be the most popular, "Center" version. In the interest of forthrightness, each model is really exactly the same except for packaging, price, and the angle of dangle in the installation instructions. We will be charging a premium for the Center model due to expected higher demand.
Installation is simple, even a non-pilot could do it after several beers. Peel your new MKV decal off backing paper and apply to inside surface of canopy, paying close attention to suggested installation angle. The MKV is guaranteed to be stable in all modes of flight.
Deciding which model is right for you is easy. If your have a heavy left foot, get the "Left" version and things will seem right (or left) most of the time. Heavy right footer should order the Right version. Helpful Hint: install all three and most always one of the MKV's will be close to spot on.
You may wish to order an old MKIV while they are still available. My guess is they are destined to become a collector's item, just as the pellet vario was made obsolete by the Electronic Pellet Vario.
bumper
Old January 7th 16, 02:34 PM posted to rec.aviation.soaring
Richard Pfiffner
Default DG quality?
Hey Bumper.
bumper
I have heard that the long awaited ULD MKV uses the new pink anti-static, low drag politically correct yarn.
Richard
Quality helicopter sim? AirDolphin Simulators 11 September 15th 06 06:04 AM
100LL Quality vlado Piloting 2 August 25th 06 07:23 PM
Manufacturing Quality john smith Piloting 100 August 13th 06 01:22 PM
Manufacturing Quality Jim Carter Piloting 16 August 8th 06 02:15 PM
What makes a quality mic? John T Home Built 11 October 10th 05 01:04 AM
