Which sustainer system would you chose for your sailplane?
Old January 14th 16, 10:19 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Default Which sustainer system would you chose for your sailplane?
IMHO, this plus a small 4-stroke generator of 10-20 hp is the perfect system:
https://www.facebook.com/gpgliders/v...5333550523888/
No noticeable drag if it fails to start, electric reliability and extreme range due to the generator.
Old January 14th 16, 11:06 PM posted to rec.aviation.soaring
kirk.stant
Looks nice, but could the drag caused by all those doors (even closed) not equal the drag of a closed FES prop?
Speaking of FES, why not have a single blade? Counterweight in the spinner (it's been around for a long time), fold the prop into a recess under the nose of the plane, cover with a door if you want to be really Gucci...
Kirk
66
Old January 14th 16, 11:16 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Was wondering how the Arcus E's (electric motor from Lange) are selling compared to the gas engine model?
Old January 15th 16, 12:36 PM posted to rec.aviation.soaring
krasw
Since Lange and Schempp are not in best terms (to put it mildly), Quintus and Arcus E are pretty much buried. Arcus E is a nice glider but propulsion system is not free of maintenance or problems.
Old January 15th 16, 08:38 PM posted to rec.aviation.soaring
Kirk
66
There would have to be something far wrong with the fit of aft fuselage engine doors before they caused the same drag as a FES prop. The flight test of the Lak FES that has from time to time been cited as showing minimal drag actually shows around 4-8 kph difference for the same glide angle with the vents open (as would be normal during most gliding) - about one generation of design difference. Diagram on page 7:
http://www.front-electric-sustainer....A%20FES_en.pdf
Front Electric Sustainer Dan Marotta Soaring 28 January 31st 13 01:32 AM
would an electric sustainer be practical Brad[_2_] Soaring 7 July 24th 09 06:29 PM
Which Came First, the Santa Monica Airport, Or Those Who Chose To Build Their Homes Adjacent To It? Larry Dighera Piloting 16 May 7th 07 10:34 PM
BAF or CEF? I chose BAF. Paul Tomblin Instrument Flight Rules 0 October 23rd 04 04:33 PM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
