And remember to do this while the fuselage is in a cradle resting firmly
on the ground. The tire and suspension will affect the frequency. -Tom I would check the manual for the method used. Some manufacturers specifically state the aircraft to be on wheel and tail skid, with tyre pressures checked to be in a certain range. Using cradles will result in deviations from previous methods used. |
Eric the issue would not be in specifics but in consistence, The actual freq number isnt that important unless it is radically diff than that given for the glider as delivered. To me, its the fact that a guy should decide a method of measurment and make a measure, then repeat that exact method to see if there is change over time or after a landing or high G event.
Dan |
ASH26 wing frequency | [email protected] | Soaring | 9 | August 25th 13 03:27 AM |
Measuring the effectiveness of a sandblaster? | Michael Horowitz | Home Built | 17 | June 14th 09 12:50 PM |
measuring flap angles for rigging | [email protected] | Home Built | 12 | April 28th 06 02:46 PM |
measuring arm distances | Heino & Deanne Weisberg | Home Built | 1 | October 21st 05 05:49 PM |
Metric measuring tool source? | DL152279546231 | Home Built | 12 | April 29th 04 02:13 AM |
